โNov-24-2016 03:45 AM
โNov-26-2016 05:22 PM
Mile High wrote:Surge Guard will 'absorb' 870 joules and not more than 1750 joules. If difficult, best is to ask why rather than post an emotion.
I for one don't understand a **** thing you are saying or recommending.
โNov-26-2016 07:55 AM
westom wrote:I for one don't understand a **** thing you are saying or recommending. Maybe everyone else understands, but I'm in the dark.Jim Norman wrote:So that Surge Guard will 'absorb' 870 joules and not more than 1750 joules. Potentially destructive surges can be hundreds of thousands of joules (clearly not billions of joules). That Surge Guard is electrically similar to other tiny power strip protectors. Effective protector works because it is earthed. And does not 'block' or 'absorb' a surge.
My built in unit is a Surge Guard 41260, protects to 2600 joules,
What was posted previously completely applies. Especially the part about how a protector must connect low impedance (ie less than 10 feet) to earth to protect from that type of anomaly. What happens when its near zero joules try to 'absorb' that energy? Those numbers should cause you pause.
โNov-26-2016 07:14 AM
โNov-26-2016 07:12 AM
Jim Norman wrote:
My built in unit is a Surge Guard 41260, protects to 2600 joules, my plug in unit is also a Surge Guard, I believe it protects to 3650 joules. I know the plug in unit works as it has caught issues at the post in a couple instances. I would appreciate learned commentary on these units singularly and in use together.
โNov-26-2016 06:50 AM
โNov-25-2016 11:41 AM
westom wrote:Jim Norman wrote:
I have a Plug-In Surge Protector.
My new Coach has a built in Surge Protector.
Those are completely different devices for completely different anomalies (as a few have noted). A 'surge' addressed by a built in protector does not do and cannot protect from a type of surge that so plug-in protectors are suppose to protect from.
What does that plug-in protector do? It claims to 'absorb' how many joules? Hundreds or a thousand? That type of destructive surge can be hundreds of thousands of joules. So what happens when its near zero joules try to 'absorb' that energy? Those numbers should cause you pause.
If your built in protector was one that attaches at the pole, then it has a low impedance (ie less than 10 foot) connection to earth ground via that pole. If farther from earth ground, it does not effectively protect from that hundreds of thousands of joules. It only protects from those other anomalies.
An 'attach at the pole' built in protector would protect that power strip. Without a low impedance connection to earth, then that power strip remains at risk.
So what is the risk? A hundreds joule surge is routinely converted by electronics into rock stable, low DC voltages to safely power its semiconductors. What that power strip protector might do is already done better inside appliances. Sometimes, an adjacent plug-in protector can compromise better protection inside appliances.
In rare cases, a near zero protector (too few joules) can fail catastrophically (create fire). A cruise ship may confiscate it if found in luggage. Threat is rare but serious enough that many do not use plug-in protectors unless protected by that other 'connected low impedance to earth ground' protector.
Only answers tempered by numbers deserve attention. Read spec numbers for a built in protector to identify anomalies it addresses. Read spec numbers for that plug-in protector (especially joules) to identify the so little it really does. Take a $3 power strip. Add some ten cent protector parts. How much did you spend for that near zero protect function?
โNov-25-2016 09:13 AM
luvlabs wrote:
Tiffin uses a transfer switch with some surge protection. It is a very basic system. It is recommended that you add a more comprehensive EMS (Electrical Management System) that also monitors ground state, high and low voltages, polarity, etc. The Progressive HW50c or PT50c are two units that will do the job. The HW is built in, the PT is portable.
I've had a HW50c combined with the Tiffin transfer switch on two different coaches and it has worked well. Best thing is that it has a lifetime warranty.
โNov-25-2016 09:05 AM
โNov-25-2016 08:20 AM
โNov-25-2016 07:55 AM
โNov-25-2016 02:55 AM
Bob & Ann wrote:
Jim
Yes you can use both. I checked with both the coach manufacturer and surge protector manufacturer. Typically your built in unit will not do all that you need it to. The second surge protector just makes for smart business. If there is a power problem that burns up your portable unit nothing in you coach is harmed. Just throw it away, buy a new one and continue on with your trip.
โNov-24-2016 03:18 PM
โNov-24-2016 09:10 AM
โNov-24-2016 08:53 AM
โNov-24-2016 07:50 AM
