Washer and dryer combo
concord_05
Our new to us 2010 itaska suncrusier has a washer/dyer combo that won't power on. Found the breaker and re tripped it but still no power. Is there a fuse somewhere I've missed? Everything else is working fine. My son is camping in it right now so haven't got to look for other causes yet.
21 REPLIES 21
hostage
crasster wrote:
Is it a heated dryer or air dry only? Heat won't be good unless plugged into shore power. Do a SLOW cycle trip on the breaker. Turn it off slow, wait, then on slow. Are you able to use a meter to make sure there is power after you put it back on?
your post makes no sense what so ever the OP very clearly stated he has NO power going to the washer/dryer combo (no lite on etc) get it?
Ed_C
If there is a cabinet above the w/d there will be a panel held in place with two spring clips. The plug and water connections will be behind it. Winnebago has their wiring and plumbing schematics available on their wed sit.
Ed/Jeanie & Slade the GSD
2017 Entegra Aspire 42 RBQ/ Sierra Crew
crasster
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
hostage
concord 05 wrote:
No but not sure how to access plug except unbolt it and pull it out. That sure sounds reasonable. Will check it out when i get it back home.
my current MH has a access box to the taps and plug in but my previous ones u had to actually pull the washer out part way to check
MrWizard
Moderator
Moderator
i was going to ask if you are on shore power ?
i would have doubts about it working on inverter
and if you have an EMS, it might Not work while you have the a/c turned on, if on 30amp shore power
I can explain it to you.
1997 F53 Bounder 36s
concord_05
hostage
no, theres no fuse BUT I know a guy that had a problem same as you and the power cord had come unplugged ?? did u check to make sure its plugged in all the way???
