Aug-17-2017 03:54 PM
Aug-18-2017 10:37 AM
crasster wrote:
Is it a heated dryer or air dry only? Heat won't be good unless plugged into shore power. Do a SLOW cycle trip on the breaker. Turn it off slow, wait, then on slow. Are you able to use a meter to make sure there is power after you put it back on?
Aug-18-2017 10:35 AM
Aug-18-2017 07:04 AM
Aug-17-2017 05:10 PM
concord 05 wrote:
No but not sure how to access plug except unbolt it and pull it out. That sure sounds reasonable. Will check it out when i get it back home.
Aug-17-2017 05:04 PM
Aug-17-2017 05:03 PM
Aug-17-2017 04:32 PM
concord 05 wrote:
Our new to us 2010 itaska suncrusier has a washer/dyer combo that won't power on. Found the breaker and re tripped it but still no power. Is there a fuse somewhere I've missed? Everything else is working fine. My son is camping in it right now so haven't got to look for other causes yet.
