โFeb-14-2018 09:32 AM
โFeb-17-2018 10:21 AM
Monkeyman_and_Lady wrote:
TechWriter,
Mind Blown on that plumbing setup. Nice work.
โFeb-17-2018 06:41 AM
โFeb-17-2018 04:12 AM
โFeb-15-2018 06:58 PM
tinkerer wrote:
This won't help you now but when I replace the filter I usually put some vasolene on the threads and gasket, I usually just have to hand tighten them they unscrew much easier.
โFeb-15-2018 05:49 PM
โFeb-15-2018 02:51 PM
โFeb-15-2018 11:45 AM
TechWriter wrote:Solo wrote:
. . . you must have connected into the outlet of the reel which on most is 1/2"NPT? So,any hints or tips there on how you did that?
Many visits to the hardware store.
โFeb-15-2018 10:03 AM
Solo wrote:
I followed your link to take a look at your Blog to see if you expanded a bit on your fresh water system and I need to pick your brain a bit.
โFeb-15-2018 02:32 AM
TechWriter wrote:
Yep. One of these + tap it with a rubber mallet. It works with my Big Blues . . .
โFeb-14-2018 06:26 PM
naturist wrote:
The right tool/wrench, maybe a little gentle tapping with a rubber mallet, it should free up. When you do get it off and go to putting it back together, you might want to replace the O-ring, and be sure to hand-tighten ONLY. Don't use the wrench for that. If you can't get it tight enough to not leak, it's a sure sign that the O-ring is toast.
โFeb-14-2018 05:25 PM
โFeb-14-2018 04:51 PM
โFeb-14-2018 03:26 PM
fischer wrote:
If your at a campground your fellow campers have the correct wrench.
You should try useing a pipe wrench
โFeb-14-2018 03:17 PM
SAR Tracker wrote:
Do you have the right wrench?
