โOct-18-2017 09:26 AM
โOct-21-2017 02:31 PM
โOct-19-2017 10:25 AM
Goldencrazy wrote:
Why would the check valve matter with the bypass. Isnโt it more likely that the bypass is not closing thereby allowing antifreeze to flow into the water heater.
โOct-19-2017 08:46 AM
โOct-19-2017 04:49 AM
Goldencrazy wrote:
Hold on all you Camping World haters. It is now in the hands of my local Camping World and they are replacing the valve.. Biggest issue is getting to it.
โOct-18-2017 03:47 PM
โOct-18-2017 03:23 PM
โOct-18-2017 01:05 PM
โOct-18-2017 12:20 PM
โOct-18-2017 11:59 AM
โOct-18-2017 10:59 AM
โOct-18-2017 10:16 AM
Goldencrazy wrote:
I have a valve to turn water heater to bypass or normal operation. A second balve that I turn to winterization that allows the antifreeze to flow from the bottle. They are both in a back compartmnet and clearly marked. Are there other valves I should turn. I have done this before and never had a problem. It is only two years old. Winterized twice as I got in the fall two years ago. So this would be number three. The settings for city or tank shouldnโt matter and all other settings are drains. They have made it seem pretty simple with all marked clearly or at least I thought.
โOct-18-2017 10:03 AM
DutchmenSport wrote:
Does yours have the 1 valve system, the 2 valve system, or the 3 valve system. If you have more than one valve, it's possible you don't have them all in the right position.
โOct-18-2017 10:02 AM
โOct-18-2017 10:01 AM
