two travelers,
I second
rjstractor comments.
If the numbers you stated are the numbers inside the rig, they differ from the Winnebago website. Here's the chassis specs for the
2023 Sprinter View.
These specs show a GVWR of 11,030 lbs., front axle rating of 4410 lbs. and rear axle rating of 7,720 lbs. Total axle weight rating is 12,130 lbs. It is not uncommon for the GVWR of the vehicle to be less than the combined GAWRs. Mine is that way. (For ours, the sum of the axle ratings is 22,500 lbs. (8,000 + 14,500) while the GVWR of chassis is 22,000 lbs.) It allows for more flexibility in loading the rig to avoid overloading an axle.
By the way, it's also not uncommon for a rig to exceed its GVWR even when lightly loaded. If the stats on the website are correct, then you're slightly over the GVWR. Not so much as to be worried about, but I wouldn't consider adding much more. Your weight also suggests that your true towing limit is about 4,000 lbs., and every pound you add inside the rig should be taken off the tow rating.
Perhaps you should give Winnebago a call and ask them to confirm the ratings shown in your rig. Or ask them to correct their website.
🙂Good Luck,
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
