Weights and aerodynamics - where do I post and query?
z89101
I am an old dodge C classer 1970's late Lindy bunkhouse 440/ MB400 163" wb GVW 9800 - but research shows build is 12.5k +
I am now gear vendors equipped and building up aerodynamic aids. Where do I post a mass query and workshop post so that others can work this project that affects all of us?
Is there a class C aero thread?
10 REPLIES 10
ronfisherman
Moderator
Moderator
ecomodder.com
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
Snowman9000
Definitely check out the forum at ecomodder.com.
Currently RV-less but not done yet.
pianotuna
Nomad III
Nomad III
I liken my class C to a flying brick. There is NOTHING aerodynamic about it. I do manage to squeeze 10 mpg US but that is by driving at 48 mph.
The air tabs made no measurable difference to mileage, except in a tail wind where I got about 2 mpg better. They did reduce wind noise dramatically.
Regards, Don
IAMICHABOD
Maybe post in the Tech Issues
There a few threads on aero using Air Foils as stated above and there are
Air tabs
Also a few threads on the subject.
HERE
And HERE
They may have some answers for you.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Bordercollie
Aerodynamic drag becomes more important as speed increases. Rolling resistance probably stays the same, running tires with max air pressure loosens fillings in your teeth.
the_bear_II
In the 10 plus years I have been reading RV and Tow Vehicle related forums the folks who post the results of changes they have made to improve MPG, the improvement has been small. 1-5 increase in MPG after spending up to $2500 in aero or engine or trans or a combo of improvements doesn't impress me.
The one thing RV'ers have done that improves gas mileage and is free is to slow down. Instead of doing 70MPH do 55 or 60MPH. It's much safer as well.
tenbear
Tech Issues or General RVing Issues?
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
ronfisherman
Moderator
Moderator
Only way to tell what your RV weighs is get it weighed at a scale.
Lots of info here on Air Tabs and other improvements on RV.NET.
Here is one thread in Truck Camper forum. It shows making a air foil to stop wind noise between and cab over and truck cab. I used Air Tabs to stop noise from wind in the cab over/cab area and cab side windows. Helped a lot. I have Air Tabs around rear of my MH. Helps with handling. But cannot tell if it helped fuel mileage.
gbopp
Good question. I don't know of any sites for aerodynamics on Class C or other RV's.
As mentioned by pianotuna, a site for air tabs would be a good place to start.
Let us know if you find any sites, I'm sure most of us would be interested.
pianotuna
Nomad III
Nomad III
There are some threads on air tabs.
Regards, Don
