What did you do to your Class C MH today???
Rich_Panganiban
This is always a fun thread to watch in other forums, so I thought I'd start one here.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
4,455 REPLIES 4,455
tenbear
snowdance wrote:
tenbear wrote:
Replaced the sparker on the stove with an electronic sparker. Now all the DW has to do is push the button instead of spinning the OEM sparker and cussing at it.
Thats intresting. My DW could use a bit less color in her language when lighting the stove.
Where did you find it?? Or what was it before you made it for your stove?????
There was a post in the DIY forum last fall. I remembered it and looked it up this spring. Click here to see the post. It has all the details.
2010 Subaru Impreza Sedan
snowdance
Snowdance
We spent most of our money traveling... Just wasted the rest..
Chevy 7.4 Vortex
2000 Jamboree 23b Rear Kitchen
http://www.flickr.com/photos/snowdance38
tenbear
Well, I didn't do all this today but in the last few weeks.
Installed a shower light. I didn't like the little bit of hallway light that managed to get thru the shower door.
Replaced some incandescent light bulbs with LEDs.
Summerized it too.
TNTraveller
We washed the outside, installed a trik-l-start to keep the coach battery charged, installed a sewer hose carrier I made from 4 inch square fence post, installed a 5,000 ohm potentiometer in line with the thermistor on our Dometic refrigerator for better temerature control (our refrigerator was freezing everything after a day or so), and installed 2 maxairs (Campmor substitutes actually)a white one in the living area and a black one in the bedroom.
Now everything is done and we are ready for summer.
Blackoctaupus
nice sunny day yesterday, Wash the outside of the MH all left is the front cab outside and inside clean up. The DW did the inside it is almost all ready to go for next weekend. We are going camping for 3 weeks.:C
Forgot still have to wax MH:S
Jacques
Itasca Spirit 29B 2005
We call it Mima!
mgirardo
We took our Greyhawk to the dealer for its last Warranty service, about 7 items. The warranty is up on Friday. Nothing major, just little things that I'd rather let the dealer do than try to rig something up.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Winniecouple
Ran the jenny with the A/C on for about 45 min, ran a shop vac inside for some heavy duty cleanup after our last trip (where we felt like the public restroom).
Put away some gear that was just tossed in on the way home last trip. Found the heat shield on the jenny exhaust has broke a weld, should be an easy fix and chance to use my little mig welder... Next weekend is our big 2-3 day Music Festival, looks like we're ready to roll.
Winniecouple
1982 20' Minnie Winnie
29,212 miles
TreeSeeker
>I will put the charged battery back in, connect the wires, reset the fuses, and hope for the best.
I suggest that you get your battery checked. After being that low, it is doubtful that it survived. I wouldn't want to be on a trip and have no battery. Better you find out now.
rgrcpa
Yesterday, I cleaned the interior making ready for a trip. I checked the coach battery putting in a little water. Didn't need a charge. I washed off my fresh water hose. DW made the bed.
Today, I have connected the fresh water hose to check the hot water heater. BUT, no power in the coach at all. Checked the battery connections which seem tight. Pulled the battery and it was down about .4 amps. Put the charger on it and I am waiting for it to get fully charged. I checked the fuses which all seem to be in the ON position. I disconnected the battery disconnect switch which I don't think is working (or has EVER worked). I filled the tires with air, checked the cab battery, and the cab fluids. DW has begun packing the clothes and groceries.
Rick Roberts
RV Part-timer
2002 Jayco Granite Ridge 32'
crawford
Yes again another fill up in Fla. 3.99 gal Giving those tax breaks to the rich oil company's make a lot of sense . And putting in all the rich crooks in congress helps also. Guess when you vote stupid you get what you get.
Change from a c class to a A class Georgetown 07 triple slide
mwebber78
Well, busy day. I de-winterized the camper today. Pain in the rear anode rod on the Subarban heater is 1 1/16" for the socket, that resulted in a trip to ACE Hardware. Anyways, I got the units water systems running and all is well.
Installed felt pads on all the drawer faces to stop them from future rubbing. I'm suprised they don't install them stock but whatever, it was a $2 investment and that was a quick fix.
I also put in the 26" LCD and Blue-ray player into a hidden cabinet.
For my last trick, I took out a standard vent in the rear bedroom and installed a Maxxair all-in-one vent and cover.
2013 Jayco Eagle 334RBTS
Disclaimer for the daft: Don't confuse my opinion with facts.
oldtrucker63
snowdance wrote:
TyroneandGladys wrote:
They called them covered wagons. http://www.flickr.com/photos/toonie52/1443184529/
Thats an early RV...
......LOL Yelp that is one right there.
Without Trucks,....America Stop's
snowdance
Snowdance
Chevy 7.4 Vortex
TyroneandGladys
oldtrucker63 wrote:
pistonsfan wrote:
Used my Kroger $0.50 off a gallon fuel reward points to fill up my gas tank...still had to pay $3.49/gal. I'm guessing +$4.00/gal gas will happen here this week.
That is bad and it's going to get worse, Get this gas right now in Venezuela is 12 cent's a gallon, I know there is some places in the world where gas is $12 dollars a gallon and some places where it is 53 cents a gallon, There is no reason for gas to be 3 and 4 or more dollars a gallon in this country, ..:h Oh well it all may end December 21 2012 We will all be back on Horses then, So they say.....LOL I wonder what kind of Horse drawn RV buggies there will be, Six horses could pull a good size unit.
Tyrone & Gladys
27' 1986 Coachmen
oldtrucker63
