What did you do to your Class C MH today???
Rich_Panganiban
This is always a fun thread to watch in other forums, so I thought I'd start one here.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
4,455 REPLIES 4,455
Jtroop1
johnbhicks wrote:
Yes, eternabonding is a verb. Judging from how often I do it, eternabonding must be my favorite recreational activity.:R
Is that because you are applying it a little at a time or you've applied in on multiple rigs?
2010 Fleetwood Encounter 32BH
johnbhicks
-C&J-
www.fugawetribe.com
Jtroop1
This weekend I:
Washed the rig, including the roof.
Applied eternabond on the front and rear seams. I still have to do the side seams and all the roof protrusions.
Bought some gutter extensions and put them on.
I am going to install an LCD tv mount in the bedrrom this week. As I get time this week, I hope to do some more eternabonding (is that a verb yet? :B ) and proflex caulk the windows/running lights.
Harvey51
I bought a nice little 12 Volt air compressor at Walmart for $50.
I never paid more than $20 for one before but this one is really very nice. It is reasonably quiet and pumps well. The 16 inch spare was down to 30 psi and this thing brought it up to 65 in 7 or 8 minutes. It didn't seem to slow down at higher pressure so I guess it is good for 80 psi anyway. The gauge on it works - no flickering of the needle and the reading is accurate. Nice long hose with a quick connect on the compressor end and a threaded tube on the other end to screw onto a valve stem.
I used a little adapter from the hardware store to change from inner to outer threads and a fitting to upsize it to standard size so I could screw on my long inflation tool which can reach into the inside wheel. I really need one with a straight end like my pressure gauge (also shown at top of photo) has, but haven't found one yet. That inflation tool works unattended (sticks onto the valve stem) but must be held onto the valve stem extenders I have. I must find an easy way to remove those extenders, which are nice for checking pressures because they don't need a cap.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
donee
Throughly cleaned it out after the last trip.
Key word is throughly.
Emptied everything out and upgraded to a Class A.
Need the extra room.:B
donnie (K7UTA) & Linda
1 rescued furrykid "Buddy"
2016 Fleetwood SouthWind 32VS
14 Jeep Cherokee
K7UTA
johnbhicks
Eternabonded the lower side seams of the cabover a day before getting four inches of rain and 50kt winds. It's no longer letting water in and out.
At least water isn't coming out...I hope it's not going in.:E
Is it against the rules to install a bilge pump in the cabover?
-C&J-
www.fugawetribe.com
racnacr
Installed a new kitchen faucet. Nice high rise that pulls out and can be used as a sprayer. Now we can wash pots and pans no problem. Not a fan of pex tubing however... I'd post pics if I wasn't so computer illiterate
05 Gulf Stream 6316
"Super James"
cal47
Just installed Borg 7" valve stems on my Rickson wheels. Can't standed the braded extensions.
Cal & Donna
Starr (our Lab mix)
2000 FourWinds Chateau 31S
Rickson 17.5 Wheels and Toyo tires
Sani-Con Sewer Solution
Pressure Pro System
1996 Grand Cherokee Toad W/Ready Brake System
Rand McNally RVND 5510
Bigfoot Levelers
Goldencrazy
That is very nice. Well done.
dsurette
Replaced three vent covers and added LED track lighting to the couch seating area. The incandescent lighting just wasn't bright enough. And as a bonus, the LEDs draw less current for more light. Will do the overhead reading lights over the bed next.
cal47
Just ordered new Borg valve stems to go on my Rickson 17.5 wheels. Also ordered one of the new bonnets Camping World sells that you can roll down and see out. Will use it on extended stays, otherwise use Easy Curtain.
Cal & Donna
Starr (our Lab mix)
Pressure Pro System
Bigfoot Levelers
ipen
i put on hellwig sway bars and bilstein shocks. it made a huge difference in the motorhome.
2009 jayco 31fs with front ent. center, bilstein shocks, 1 1/2 inch sway bars, with 2001 jeep cherokee in tow and unified tow brake system
rondeb
Actually done a few months ago after we took our first trip with our new to us Class C and before we headed out for a 4 month trip (we are still on it)
We had the old captain chairs, single lone little chair and dinnette taken out and replaced with new flexsteel captain chairs, a 74" sofa and had a cabinet made and put our TV where the lone little chair was. Picked up 3.5 feet of floor space and made sitting in the evening watching TV or just reading so much more comfortable.
Replaced all the carpeting and lino. Made the shower into a closet (we just use all the parks showers now)
"OLD"
NEW" We use 2 of the folding tables shown behind the lone chair as our desks and tables now. They fold up and go on the bed while traveling or when we aren't using them. We also had the little table that slides under the edge of the sofa between us made by a gentlemen off of Ebay. I gave him the dimensions and he made it to order.
This one shows the TV cabinet and how we relocated the TV across from the couch
This one shows the material that I made all new curtains with along with our shower closet (added so much storage that I could never live without it now)
This one shows the new kitchen faucet and filtered water dispenser we installed Also shows the huge counter extension we did last summer.
TyroneandGladys
Not done today but a since we got our new to us last weekend. Last week replaced EGR valve to get her to pass emissions test, generator had some issuses from not be used enough, 831 hours in 24 years, so had a complete service with output adjustments done and Gladys stowed everything away on the inside. The bed has one corner cut at an angle so cut a piece of plywood to lay on top of bed,doing away with the cutout, supporting the end with leg for support. Mattress is now a futton mattress with a 2 1/2" memory foam topper.
Got back Sunday from our first outing. Replaced the front tires today with Yokohama's Geolandar H/T-S going from load rating D to E. Tomorrow having the front fuel tank's fuel pump replaced.
As that famous pig said thats all folks, for now.
Tyrone and Gladys
Tyrone & Gladys
27' 1986 Coachmen
Berticus
Weekend update,
Got the BD exhaust Brake back and put her on the beast, still need to test it fully on the road. BD Diesel Preformance is a great company. I shipped to them the whole exhaust brake with cylinder and they could not fix the cast brake section so they sent back a new one with a rebuilt cylinder as will as my old one. This did cost a little bit but was no where the $1000 for a new one.
The RV is now summerized for the next trip.
Happy camping, Robert.
The Setup:
96' Serro Scotty 25'Dodge,4x4,Diesel,Class-C, 86 20' Chris Craft LTD.
