Which weight for South Dakota registration?
Monty-Rob
Which weight do they use for South Dakota registrations of a motorhome.
Looking at weights I see GVWR and GAWR noted for some motorhomes?
I
2014 Lifestyle 37CKLS (Sold January 2018)
2008 Ford F-450 Lariat (Sold January 2018)
2012 Started fulltiming on February 1st (stopped fulltiming December 21, 2017)
8 REPLIES 8
dons2346
Monty-Rob wrote:
Agree....SD wants UVW, but where can you find this number when looking at specs online...I have not seen this weight noted....guess you have to call manufacturer
There should be a data plate somewhere in the coach
Monty-Rob
dons2346
Old-Biscuit wrote:
UVW (Unloaded Vehicle weight) Dry weight/Brochure Published Weight Etc
GVWR (Gross Vehicle Weight Rating) Maximum Weight Vehicle is Rated for
GAWR (Gross AXLE Weight Rating) Maximum Weight Axle is Rated for (by RV MFG.)
GCVWR (Gross Combined Vehicle weight Rating) Maximum Weight of Vehicle AND Towed Vehicle Weight
SD Registration.......License Plate
These fees are based on the weight and year of the vehicle.
(GVWR) plus AGE (split schedule 0-9 yrs and 10+ yrs)
Unless things have changed since I registered in SD back in '03, they wanted dry shipping weight.
I suggest the OP call the treasurer's office to verify.
Bill_Satellite
I could not get the unloaded weight but if you can find it you will save money. I had to go to a weigh station and weigh the coach so I paid a bit more than I would have needed to if I had the correct information.
Can't we all just get along?
Old-Biscuit
dons2346
They want dry shipping weight also known as UVW (unloaded vehicle weight)
jpmihalk
When we registered our Hurricane they wanted the weight from the manufacturer's certificate. This is typically the GVWR.
John & Kerri
2016 Thor Hurricane 35C with our pups MacDuff, Piper and Annabelle
sgip2000
Most likely GVWR.
