โMar-23-2017 05:32 AM
โMar-25-2017 06:24 PM
โMar-25-2017 05:12 PM
โMar-25-2017 03:18 PM
โMar-25-2017 09:31 AM
Likes to tow wrote:
Yes it was!! My friend was ready to make a deposit but after we raised the cushions and saw the stains we made a closer inspection of the outside. The caulk had open cracks in it along the aluminum trim strips and there was mold on the underside along some seam caulking. I'm afraid some unsuspecting buyer is going to get burnt!!
โMar-25-2017 04:04 AM
Photomike wrote:
Someone told me a few years ago: "Imagine if your stick house was subject to an earthquake for 4 or 5 hours a day, it would start to leak and fall apart like a RV does".
I think a lot of time it is build quality but a lot is also we just don't take into account how much stress we are putting on these units and how much we need to do to keep them in good shape.
โMar-25-2017 03:57 AM
Newbiecampers wrote:Likes to tow wrote:
My friend found an unbelievable deal on a used 2011 with only 3800 miles on the clock and wanted me to go look at it with him. It was in unbelievable condition for a 2011!! It had been stored under a roof mostly out of sunlight and rain. I could find nothing anywhere from top to bottom that looked questionable until I looked under the mattress in the over the cab bed. There were water stains on each end of the mattress on the bottom side. Close examination on the outside revealed water oozing out from the edge trim molding when you pushed on it. A classic example of lack of proper maintenance sealing. The owner was really shaken up by our findings and had no idea Class C's are famous for this. Now he was faced with a huge repair bill before he could sell it unless some poor unsuspecting buyer did not look under the mattress.
Was this by chance the 21qb that was recently on ebay in Ohio? We had thoughts of going to see it but changed our mind due to a few issues regarding it.
โMar-24-2017 09:46 PM
โMar-24-2017 11:10 AM
โMar-24-2017 06:53 AM
Biggyniner wrote:Desert Captain wrote:
A properly designed/engineered and built RV should need no additional caulking whatsoever. If they got it right you should have no leaks for years. Using a one piece fiberglass roof is getting it right. It's the same for one piece fiberglass end caps that do no have any upward facing gaps.
IMHO: Re caulking a Class C to stop leaks is like having to add modifications to the suspension... there simply should be no need to do either. I have yet to encounter another Nexus owner with leaks and the same holds true for Born Free, Phoenix Cruiser and Lazy Daze {to name just a few of the better designed/built C's out there}.
When builders {who know better}, continue to build coaches with rubber roofs, Luan, 2 X 4 framing and host of other cost saving shortcuts it quickly shows in the overall quality {or lack thereof}, of the coach.
As always.... Opinions and YMMV
:C
I guess it depends on your definition of "proper". In my manual it states to inspect and re-caulk as necessary, at least twice a year. That is what is in my owners manual.
So I guess my philosophy of inspecting twice a year may be overkill for say, someone who owns a Fiberglass one piece rig.
In the end, read your owners manual and do as it says...
โMar-23-2017 09:18 PM
crasster wrote:
Yes, they are notorious for front bunk leaks. Many MFG's even quit putting windows on the bunk area, but still, they can tend to leak. The best think IMHO to do with a C if you like them is to keep them in covered storage and so that it won't be victimized by the elements all the time. Does it stop leaks? No, but water won't get in it if it's covered under storage. It's a great way to "stop leaks" and preserve the coach.
โMar-23-2017 05:52 PM
โMar-23-2017 05:30 PM
:C
โMar-23-2017 03:48 PM
:C
โMar-23-2017 03:00 PM
โMar-23-2017 01:10 PM
ScottG wrote:My dad has a 1998 Chinook Concourse. The body is a one piece fiberglass tub. No seams, no caulk, no leaks. Of course, when it was new it cost as much as a 4 bedroom house in the suburbs, but it won't leak. You are absolutely right, ScottG... No goop, no leaks.
Until the industry gets away form using goop to keep water out leaks will continue to happen.
