โOct-15-2014 10:26 AM
โOct-21-2014 05:51 PM
โOct-16-2014 01:55 PM
JCGibson wrote:msmith1199 wrote:JCGibson wrote:msmith1199 wrote:
I'm so lazy I go to a place where I don't even have to get out of the car to have the oil changed!
That's awesome! I would do that if I didn't even have to get out. I have never heard of anything like that around here. Maybe a business opportunity...
The place is called Oil Can Henry's. It's chain outfit but I don't know how spread out they are. You pull your car into the bay and they hand you the newspaper and you sit and read the paper while they do the work. They even push a TV monitor over to your window with closed circuit cameras on it from under your car so you can watch the work being done. I'm usually in and out in under 15 minutes.
That is too cool. Might be a calling around here for something like that.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โOct-16-2014 12:00 PM
โOct-16-2014 10:44 AM
โOct-16-2014 10:27 AM
โOct-16-2014 09:19 AM
โOct-16-2014 09:14 AM
msturtz wrote:JCGibson wrote:
Another couple questions I would like to ask, how accessible is the engine on these? Is it possible for me to do all the regular drive train maintenance on a DP or gasser? I usually do most everything required on my Dodge (especially since it is out of warranty) and our 5er (at least I have the previous ones).
In theory it is possible. Not easy but possible. Initially I wanted to stay away from a DP for that reason. However now there are YouTube videos on exactly how to do the work. I even saw a video on how to do your own maintenance on a diesel generator! BTW DP units have commercial engines and transmissions and have much longer service intervals vs. gas rigs or even diesel pickups.
โOct-16-2014 09:13 AM
Although this isn't a bad idea, if you are going to look for an older high end DP, just make sure you have somebody who knows what they are doing inspect it closely for any hidden damage from water or things of that nature.
What areas are prone to water damage or other type of damage? Do you mean from the roof? I am pretty mechanically inclined and have pretty good knowledge of 5ers and my Cummins Diesel in the Dodge so isn't this something I can inspect?
Roof leaks allow water to get into walls and cabinets and other places. A few cheap pieces of trim and/or some paint can often hide this damage from an unsuspecting new buyer. There was a thread on here a few weeks ago from a person who was in the process of purchasing a used motorhome and found out that the seller had used some trim pieces to hide water damage to a wall.
โOct-16-2014 09:11 AM
โOct-15-2014 06:47 PM
JCGibson wrote:holstein13 wrote:korbe wrote:
If I didn't use my truck at all except for pulling the 5er, I would consider a Class A also.......But I use my truck all the time.
I consider vehicle engines sitting idle not a good use of my money.
I pull my 2012 4 x 4 F150 super crew cab behind me. It's a great toad.
Do you have a DP or gasser? Most gassers, which is in our budget, don't have that towing capacity.
โOct-15-2014 06:19 PM
โOct-15-2014 04:30 PM
Water damage in RVs is very bad. You can check by looking at the seams where they used Dicor sealant. If it is a patchwork of sealant that is actually good. It means that they are inspecting and resealing the roof regularly. If not, that is bad. Also you can get a electronic water detector at Costco or other locations that you put up against a wall and it will tell you how wet it is. It does not damage the finish or put holes in the wall. Another thing to look at is the ceiling if you see water spots that is a red flag.
โOct-15-2014 04:28 PM
โOct-15-2014 04:13 PM
