Feb-25-2014 09:36 AM
Feb-26-2014 01:37 PM
Feb-26-2014 05:58 AM
Feb-26-2014 05:23 AM
Feb-26-2014 04:37 AM
Feb-26-2014 12:34 AM
Feb-25-2014 09:41 PM
Feb-25-2014 07:56 PM
BobandShaz wrote:wny_pat wrote:becker wrote:Don't know what isolated areas you are headed to, but there are some in western Texas, like around Langtry, where nothing works!
We are headed out to some isolated areas on a extended road trip.
Same in SE New Mexico. Reason we are looking into this..
Feb-25-2014 07:28 PM
Feb-25-2014 07:20 PM
Feb-25-2014 07:02 PM
Feb-25-2014 05:02 PM
Feb-25-2014 11:28 AM
Feb-25-2014 11:16 AM
Executive wrote:
I use the Wilson 801245 amplifier with an external antenna. There are two antennas available and I've had success with both.
The first is an 18" magnet mount that I simply attach to a cookie sheet and lay on the ground under the motor, then run the cable thru the engine compartment into the bedroom. The other is a trucker antenna, Wilson 301133, which I mount to a 10' piece of PVC which I attach with bungees to the ladder on the rear of the coach. The cable is run the same as the 18" one.
Inside the coach I have a PremierTek ANT-P8025 attached to the amplifier and I use my phone as the hotspot....hope this helps.....Dennis
Feb-25-2014 10:52 AM
