Winterizing
ronheb454
I am new to RV's and have a new 2015 Thor Miramar 34.1. I was getting my RV ready for winter since the temperature is supposed to hit 30 degrees tonight. I have a bath and a half so I have two sets of grey and black holding tanks. All the holding tanks were emptied after camping last weekend. I by passed and emptied the water heater. I removed the water filter. I emptied the fresh water tank and ran the pump until no more water was coming out but about an inch remains in the bottom of the fresh water tank. Is that a problem. Should I remove the line going to the pump and make sure no water remains in the pump as well? I preferred to handle the fresh water with air so I applied about 55 psi with all facets open. Most had a little water come out except the rear master bath sink facet. No water came out but I couldn't hear any air either. Could that be a problem? Being new and never doing this before I am not sure. I poured some RV antifreeze down all sinks, shower and in both toilets. Any help or suggestions would be appreciated I just want to make sure I am doing this correctly, thanks much.
14 REPLIES 14
ronheb454
I am going to try that, thanks.
Gary_
Instead of opening all faucets at once I think you will get more water out of the lines by only opening one faucet at a time as more air volume will go through each line.
racer99
2000 Fleetwood Flair/32'/v-10 motor/F-53 chassis
I/we hook air to MH blow air out of each faucet,then connect hose to inlet of pump,put hose into rv antifreeze and run pump open each faucet till pink stuff comes out,don't forget outside shower,I run 4-5 gals through valves then pour 2 gal in fresh water tank,1/2 gal in the sinks & shower and pour a gal into toliet,then I turn pump on and run water till it comes out all valves.Maybe a little over kill but 10 gals cost less than 30 bucks and in 5 yrs never had a problem-If you have one pipe in the system freeze you will wish you ran the extra pink stuff through the system
ronheb454
Yes, I did thanks.
AllegroD
Did you open the low point drains, also?
TempatureContro
Also do not forget to blow out the outside shower, outside faucet and toilet sprayer IF you have these.
Coyote74
Make sure when u blow it out u depress the toilet valve to. and drain any washer hook up valves.
Joe Taylor , Good Sam Life Member
FMCA #285032
2004 Winnebago Adventurer 38R
Life's a trip, RVing makes it an incredible journey.
ronheb454
I only put antifreeze in the drains and did not run antifreeze through any of the fresh water lines. I only blew them out with air.
I will go back through the procedure again closing all facets this time and start by opening the farthest one from the pump.
As mentioned I will check the strainer on the inlet side of the pump.
Thanks everyone for your advise. Hopefully I will get a chance tomorrow afternoon to check these out. I'll let you know, thanks much.
Lumpty
Depending on your plumbing layout check the strainer on the inlet side of the water pump. The year I blew out the lines, all was well except that item still held some water at the bottom and ended up with a hairline crack due to maybe a thimble full of water that settled into the inlet, which in my RV is pointed down. They do disassemble easily so the screen can be cleaned, as well as any bit of water removed.
Rob
Too Many Toys.
- '11 E450 Sunseeker 2300
- '16 F150 Supercrew 5.0/FX4
- '09 C6 Z51
- '15 VW Golf Sportwagen daily driver
- '86 Civic and '87 CRX race cars
Dakota98
Well, it seems you have enough air compressor volume, no question there. Volume is more important than pressure.
Quote:
"Should I remove the line going to the pump and make sure no water remains in the pump as well?"
You can run the pump until dry, won't hurt it.
"I preferred to handle the fresh water with air so I applied about 55 psi with all facets open."
Actually, it's best to not open all at the same time. Go to the furthest point from the pump first & work backwards.
"Most had a little water come out except the rear master bath sink facet. No water came out but I couldn't hear any air either. Could that be a problem?"
That is strange, especially with that size of compressor. I would start over with the procedure mentioned above.
PS: When using air, there is no need to mess with the water heater by-pass system. The very first step with air is to drain the tank & re-insert the plug & go on from there.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
lots2seeinmyrv
Did you run the antifreeze through each faucet and the outside shower until it comes out pink? Or just blow the air through the lines?
1492
Moderator
Moderator
Moved from Forum Technical Support
ronheb454
50 gallions
Dakota98
How large is your air compressor ? 6- gallon ?
2006 POLARIS ATV
USMC 68-74
