Microwave/Convection Wire Racks
cbinpa
We just installed a new microwave/convection oven in our 5th wheel. I have read and re-read all the manufacturer's literature,and can't find whether you can leave the 2 wire racks in the oven when using it in microwave mode.
Hoping someone here can provide an answer for me. I do note it says you can use small flat aluminum foil to shield food, so long as it is 1" away from the walls. Thanks for your input!..
16 REPLIES 16
cbinpa
Thanks again for all your input regarding my original question. I did finally email Sharp Corp. customer service and received a prompt reply, as follows:
After researching your question, the wire racks are not recommended to
be used while using the microwave portion of the unit. The wire racks
are only recommended when using the convection portion of the unit.
I emailed back to inquire about the "mixing" type use where the oven goes from microwave to convection, mixing the type of use, as someone above mentioned. I have not received a reply to that question yet.
NYCgrrl
wca01 wrote:
On a Sharp you can select any convection temp shown on the keyboard and that's all, but what more do you need.
You can't enter something on the keyboard like 352!
Good Luck!
Wil
I've been doing a lot of "slow cooking" of late and often need a temperature in the range of 200-250 degrees and yes, you are right, there is no way to program that temperature directly. So I set the oven at a higher temp and using a digital probe thermometer plus open and shut the door method to adjust the temperature. Be nice to not go through all those gyrations.
wca01
Good Luck!
Wil
NYCgrrl
The OP's question caused me to ACTUALLY read my manual from cover to cover for the first time ever:D.
Things I've learned so far:
When your mother house sits and you no longer have audible sounds between cycles and usage... do not assume she broke something and glide over the fact w/ your SO.
Press the "Custom Help" button (yanno, the one you've been glossing over for decades that's located at the top of the panel?)then "2", then "Start/Stop". It will either turn sounds on or off.
Combo cooking method....just hit me over the head and have done. Never ever done it.
Still reading to find out if I can convection cook at at temperatures not located on the presets without my normal gerrymandered version;).
Reading really IS fundamental:p.
NYCgrrl
Press the "Custom Help" button (yanno, the one you've been glossing over for decades, that's located at the top of the panel?)then "2", then "Start/Stop". It will either turn sounds on or off.
Combo cooking....just hit me over the head and have done.
wca01
I have used several Sharp convection/microwave ovens over the years in both RVs and Stick and Brick. I have used both wire racks for microwave. convection, and combo cooking for all of those years.
Note that the "High Mix" for roasting and "Low Mix" for baking options combine both microwave and convection cooking and a rack is specified for roasting and baking.
Of course, the purpose of the wire rack is to get heat under the item being cooked. Use the rack when that need is indicated.
since it causes no harm, we leave the low rack in the oven for storage all the time.
Our large Sharp at home has a metal turntable.
Good Luck!
Wil
Scottiemom
My new Frigidaire didn't say either, but I use it like my Sharp. Racks are used when using convection, out when using microwave. Actually in the Frigidaire, the wire rack is used on convection when using a 9 x 13 pan. The turntable cannot be turned off, so you put the rack in above the turntable and place the pan on top. It also has the stacking rounds racks for doing two layers of cookies, etc.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Sportsman2505qs
I Would call sharp and ask them. I have a Sharp in my Kitchen and it has all medtal inside and I leave the rack in when cooking all the time.
2002 KZ Sportsmen 2505qss bought in 2001 Sold 1999F-150
Itasca Spirit 2014
Manatee Hammock
cbinpa
Thank you all for your thoughtful answers. This is a Model R1874/1875 Sharp. I cannot find an answer to the question in the manual; and different folks seem to have different opinions. I am thinking I will just remove the racks each time I use the microwave function, just to be on the safe side. Finding a place to put them away in my packed kitchen is the only issue. Once again, thanks for your input---and if anyone finds anything definitive in future, please let me know..
NYCgrrl
I've a Sharp microwave/convection. Same version for over 20 years and it states clearly in the manual the metal racks are ONLY for the convection function. This info is listed under the bolded subtitle "Accessories" at the bottom of page 10(English version) of the manual for models R930AK/R930AW/R930CS.
HTH
SteveRuff
I leave my racks in all the time. Many of the settings are using both convection and microwave so it is obviously okay to do so. I have never seen a spark like used to happen with older microwaves when metal was inside.
Both retired. Travel with Nicky the Schnoodle. Son graduated and is teaching high school math. We still love our 2006 34' Allegro Bay XB and have 50,000+ miles on her.
Crazy_Ray
Take the racks out when using MW.
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
dahkota
I don't leave the racks in mine when strictly using the microwave function.
However, there is a convection roast function which uses both the oven and the microwave(at 20%) and the instructions specifically state to use the rack. I have done so with no harmful effects to either food or oven about 1/2 a dozen times. But, I have only owned it for a month so far.
On edit: I do not remove the turntable or an part of it when using the only the oven.
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
blangen
You don't mention the brand but, if it's the Sharp CS-930 convection microwave, the answer is yes (use the racks on microwave if that's what the manual says for what you are doing). But this is all fairly new to me, too. We've had this unit for about a year and I'm still referring to the manual. I remember... in the olden days, we didn't put metal of any kind in the microwave... and (for me, anyway) that concept is hard to ignore. So... until you are used to it, refer to the manual often and you should be fine.
Another edit added: Given the other answers that are, apparently, all over the board, I'd say the answer to your question is extremely brand/model specific. For example, the Sharp CS-930 says to use the rack (without removing any other parts) to microwave popcorn.
