โApr-06-2017 09:28 AM
โApr-06-2017 11:04 AM
โApr-06-2017 10:48 AM
โApr-06-2017 10:47 AM
DutchmenSport wrote:
Well, this may sound a bit corney, but here it goes!
Considering my truck has a construction shell on the bed, I put a hook right smack in the middle of the rear window door that lifts up. I then have a 1/2 inch dow rod with another hook in the end. When both ends are hooked together, the rod hangs. Once it quits swinging so much, gravity??? .... does what? It pulls straight down! The rod acts like a plumb line, perfectly straight up and down now.
On the trailer I have a set of marks (right smack in the middle of the nose cone) that are straight up and down, and in view through the rear window of the truck and shell.
Now, when back up, it doesn't matter how crooked (side to side) the truck is, the rod always hangs down straight. Once the two marks on the trailer nose are exactly parallel, I have a perfect level trailer side to side! It works every time!
Front to back, after unhitching? I have a small bubble on my electric tongue jack.
Technology is so over rated! Go back to the simple mechanics of gravity and leverage and you too could build a Roman aqueduct that runs a hundred miles with only a inch or two difference in fall from the beginning to the end using nothing but water as a your measuring tool.
โApr-06-2017 10:21 AM
โApr-06-2017 10:01 AM
