Best/easiest internet setup for working remote/full time
way2roll
Navigator
Navigator
Over the next year we are looking to go full time. We have a class A. I am in the preliminary stages of setting things up. Forgive me me if this has been covered in depth ( did a search and found lots of info) but I would like to corral my thoughts to one post. First, I work remote now, just in a sticks and bricks. I have worked on the road for small trips before with a hotspot. Worked ok but of course it wasn't full time. My internet demands aren't unusual so "normal" internet will suffice. We also plan on continuing to use our streaming devices for TV etc. My work provides a corporate account via ATT and I have truly unlimited internet - provided it's via an ATT supported device. But I think I need something a little more bullet proof than just a hot spot. Thinking boosters, repeaters etc. I don't want to address geography here, I know I will need to be in range of a decent signal when we camp. We are touring the US, but logistics to maintain connectivity are a condition of planning. But what I do need is to ensure I have a pretty easy setup, to provide reliable internet. I will say I am NOT tech saavy. I wouldn't know know gain on shibaba shaboola over signal strength of flim flam. I am handy, done some electrical, well versed at building and repairing things etc, I'm not dumb, it's just that electronics and IT are not my forte'. So an easy, reliable plug and play set up is preferred even if it means it will cost more. In short, what do you all use that's easy, and reliable to maintain connectivity while travelling - reliable enough to work (provided you put yourself in range of a signal)? FWIW, I've looked at weboost systems etc. Sorry for the ramble and duplicity as I know this has been covered in pieces before. I just need it spelled out. Thanks.
Jeff - 2023 FR Sunseeker 2400B MBS
19 REPLIES 19
way2roll
Navigator
Navigator
This thread is almost 2 years old but I guess it still has merit. We never did our full time/part time switch. Covid threw a major kink in the whole works. So we put the plan on hold. We have the truck and FW now and I have our new ATT hot spot with unlimited data and so far it's worked perfectly.
1492
Moderator
Moderator
It's a moot point how well a WiFi Repeater works if the campground's available internet bandwidth is poor to start, which is a common complaint. Better to find your own mobile data that works for you.
Verizon Visible unlimited 4G/5G data is an inexpensive option at $25. month. Just join any Party Pay group, easy to find.
way2roll
Navigator
Navigator
Thanks all for the replies. very, very helpful. I tend to over think things and sounds like that's the case here. My plan is 2 hotspots one ATT and one VZ, and sit on a booster or external antenna and make that decision later whether I think it's worth the investment. I almost forgot that alternative work sites like Starbucks could serve in a pinch if we land somewhere and my setup doesn't provide a signal. And I totally disregarded CG wifi - sounds like I should make it a habit to test that as well.
I do recall when we toured the East Coast of the US years ago armed only with a VZ jetpack, I can't remember anywhere we didn't have a signal. Those were vacations so I wasn't working during those trips, and we didn't stream TV at the time, but my wife was on the laptop daily and never had any issues.
Gulfcoast
I'm real happy with my Visible service. I only use it for data and it works well for me.
I can't beat $25 a month (total bill) for all the Verizon data I need.
I do have true unlimited AT&T data at $20 a month, but that's another story.
RV'ing since 1960
Dodge Cummins Diesel
Mega Cab
Jayco Travel Trailer
TechWriter
way2roll wrote:
Questions - your ATT Mobley - is that a plan or a device? Would this be the same as an ATT hostpot on my existing unlimited plan?
The AT&T Mobley was a mobile auto hotspot that is no longer offered. It sounds like your hotspot is similar.
way2roll wrote:
The hughesnet - I am assuming this requires some sort of a dome or dish, the former being self orienting and the latter being a manually positioned dish? Either seems like a costly investment. We only plan on full timing or 6 mos to a year, so I'd rather keep costs down. If I were to sell the house and FT forever, I can see where the cost is justified. I had Hughesnet years ago for Sat internet when we lived in a remote area. Latency was horrible. I ended up with a VZ hotspot and although signal was weak, it was bounds better than the HN. This was years ago and I am told things are much better now. A friend of mine is an engineer at HN, tells me things are night and day different than my old setup. I think the biggest issue with SAT is cost. But it also provides coverage where nothing else works. Would it be smarter to forego a hotspot altogether and just rely on SAT 100% or is there a line of sight issue that can make it unusable? Looks like their packages are pricey.
HughesNet Gen 5 is really a full timer (12 months a year) option. A portable HughesNet Gen 5 system will set you back about $1500 and a HughesNet Gen 5 automatic rooftop system can cost over $6000. However, in your case I recommend just picking up a Verizon hotspot like Visible.
The current HughesNet Gen 5 is much better than the HughesNet of years ago. While I've seldom seen the 25 Mbps download speeds advertised by HughesNet, I did find consistently good speeds. Here's my latest HughesNet Gen 5 evaluation.
way2roll wrote:
Are you advising against a booster altogether?
I've found them pretty worthless, but YMMV.
www.rvSeniorMoments.com
DISH TV for RVs
philh
I'm going with OTR Mobile
site
Here's one review
here
Bill_Satellite
way2roll wrote:
Am I overthinking this? Is it truly as simple as a hotspot and possibly a booster like we-boost?
Yes, you are overthinking this! A hotspot is a name for a device that provides you with an internet connection. At home you would have a router that does the exact same thing. It's just a different name. Use your hotspot with a good external antenna and you will have as good a service as the location allows.
As an aside, the TOGO could be that external antenna you need in likely one of the most simple setups available. For whatever reason Winegard won't send me one to review so I can only tell you have I have been using a hotspot for many years as my ONLY internet connection and I move around the Country from Coast to Coast without issue.
Can't we all just get along?
wanderingaimles
way2roll wrote:
To clarify, my work does not pay for my internet, but we have a contract for a drastically reduced price. It's like $15/mo for truly unlimited data per device. So at 3 phones and a hotspot I would be looking at less than $100 - not bad.
I looked at ATT TOGO and read some mixed reviews. I am not afraid of bolting something to the roof but if there is already some foretasted obsolesce, I'd rather go another route.
Am I overthinking this? Is it truly as simple as a hotspot and possibly a booster like we-boost? We don't plan on going off the beaten path too much aside from some national parks. If we find there are places we want to go without good reception I plan on using up vacation time - I have a good bit of that.
I have read that redundancy with another carrier like VZ is a good idea. We had VZ before and I was impressed with the coverage. But my company has no contract with them so this is a cost consideration. Maybe a pay-as you go deal. I assume boosters like weboost can toggle between carriers.
I am sure I'll get more familiar with setting things up, using directional finders etc to maximize connections, but I'd rather figure out most of this now, so 1- I am not caught without a connection more than I can manage, and 2 so I am not wasting cash and re-engineering a setup several months in.
Short answer I think is YES
At $65 to $80 get a cheap android for a month or two.
GO Travel, Knowing that IF you run into a problem you can activate the Verizon phone as a temporary patch.
You may like and want to keep, or you may not, and discard. Either way, with no contract plans , YOU choose as you see fit.
way2roll
Navigator
Navigator
theoldwizard1 wrote:
Winegard/AT&T TOGO (aka ConnecT). Easy to install and configure. Can be used either as a "hot spot" (convert cell phone signal to local WiFi) OR a WiFi extender/repeater if you camping location has adequate bandwidth to the rest of the internet (personally I would not bother especially if work is paying for the data).
Connects (wirelessly) to multiple device in the coach. If your phone supports it, you can make calls through it also.
EDIT : This is also supported on Verizon, but you have to change the SIM card. Not real easy if mounted on the roof.
Was looking hard at the TOGO. Since I already have ATT this makes sense, however I think redundancy is important and so I was thinking of VZ as well. Sounds like to use the TOGO for multiple carriers I'd have to swap SIM's which is not ideal. If I had ATT and VZ hotspots, would a weboost be fairly equivalent to a TOGO with added advantage of toggling between carriers? What's the benefit of TOGO over hotspots with a booster?
way2roll
Navigator
Navigator
TechWriter wrote:
way2roll wrote:
Over the next year we are looking to go full time . . .
(1) My internet demands aren't unusual so "normal" internet will suffice.
(2) We also plan on continuing to use our streaming devices for TV etc.
(3) My work provides a corporate account via ATT and I have truly unlimited internet - provided it's via an ATT supported device.
(4) But I think I need something a little more bullet proof than just a hot spot.
(5) We are touring the US, but logistics to maintain connectivity are a condition of planning.
(6) But what I do need is to ensure I have a pretty easy setup, to provide reliable internet.
Your "normal" Internet needs became much greater with (2) - streaming. To me, that means a reliable 5 Mbps connection. This can be an issue.
First, I've been a full timer for several years. Here is my Internet setup -- AT&T Mobley (unlimited), Verizon data plan (40 GB/mon), HughesNet Gen 5 satellite Internet. With these I was never without Internet last year. See my Campground Internet Report 2 (43 campgrounds).
With AT&T and Verizon coverage (+ campground WiFi), you should have "usable" Internet most of the time.
Though I've tried several, I typically don't rely on WiFi "boosters" because if you don't have a signal, then no amount of boosting will help. My HughesNet Gen 5 setup gets me out of those no signal situations because if you travel a lot, you'll find areas with very weak or no cell coverage.
I suggest you check out the Mobile Internet Resource Center.
Good info. Questions - your ATT Mobley - is that a plan or a device? Would this be the same as an ATT hostpot on my existing unlimited plan?
Are you advising against a booster altogether? I do know that no signal can't be boosted, but a weak signal that's boosted can mean the difference in being able to work or not. With my former jetpack, I know even tiny antenna sometimes made a big difference.
on Edit: I reviewed your internet report - as an analyst I geeked out on it - good info and very helpful. Seems like already having the ATT is a good bet, especially given where we plan on travelling. It also seems like having a VZ hotspot as a backup is smart, maybe on a limited plan. It does not seem like the hughesnet is a worthy investment given the length of time we plan on FT and the amount of coverage the 2 cellular plans offer. I did not see in your tests if you used a booster, wonder how that would have impacted the results.
Of course this all leads to more questions, like would I even need a router or repeater given that hotspots are in and of themselves routers? I want to keep my install clean and easy, but I also want to maximize my connection(s).
TechWriter
PNW_Steve wrote:
I recently switched my phones from AT&T to Verizon's Visible service.
I also purchased a Visible "hotspot", but did not switch over entirely because I've heard horror stories from people who had switched over both their voice and data to Visible.
I use Visible for data only. Though it's an "unlimited" data plan, Visible has a few gotchas . . . it's only 1 line, so you can't share it. Visible is capped at 5 Mbps. However, it's an ok standby plan.
DISH TV for RVs
TechWriter
DISH TV for RVs
Dick_B
Have you considered Hughesnet? Seems tailor made for your situation.
Just my $.03.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
PNW_Steve
I purchased an AT&T hot-spot and got setup on one of the iPad unlimited plan. When it works, it works great. Unfortunately coverage is hit and miss in places that we visit frequently. It is $35 a month for unlimited data that is supposed to be unthrottled. I have had it for about eight months and have flogged it pretty good while binge watching Netflix. No sign of throttling yet.
I recently switched my phones from AT&T to Verizon's Visible service. I have tethered it to a Wi-Fi router and have been very happy with it with one BIG exception. I fly in & out of Pasco Airport (PSC) and find that I really need my phone there. Unfortunately Verizon has no service there. That shocked me.
The Visible service costs $25-$40 a month. One phone is $40. If you have others join your "party" it goes down $5 for each person. We have two and room for two more. We are paying $35 each with all taxes and fees included. When we fill the two remaining spots we will all be paying $25 each.
Unlike "family" plans that we have tried before, each phone is billed separately. So, if Johnny joins my group and does not pay his bill, I am not liable and my service is unaffected.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
