โDec-29-2014 05:37 AM
โJan-22-2015 04:20 PM
cleo43 wrote:Digital cameras made in the last 15 years all have built-in UV filters on the sensor.
You mean 'anti-aliasing' filter ?
โJan-22-2015 03:57 PM
โJan-22-2015 08:39 AM
scbwr wrote:mabynack wrote:
You probably need to clean the autofocus sensor. Also try cleaning your lenses. I always keep a UV filter on my lenses and replace them about once a year. It's a lot cheaper to replace the filter than the lens.
Why do you need to replace the UV filter?? Isn't taking them off periodically and cleaning all you need to do. I use UV filters on my lenses but certainly don't need to replace them. I'm just curious...don't mean to imply anything but that.
โJan-16-2015 04:15 AM
โJan-15-2015 05:36 PM
coolmom42 wrote:
Digital cameras made in the last 15 years all have built-in UV filters on the sensor. There is no need for an external UV filter. It is another source of optical degradation & chromatic aberration. The only possible purpose it serves is protecting the front lens element. That can be done very effectively by using the lens hood turned the right way.
โJan-15-2015 05:02 PM
It's personal preference. Could be the thought that the UV filter becomes scratched with time and it's better to replace it, or that after X number of cleanings, it gets a bit fuzzy, etc., that additional cleaning can't correct. There are more opinions on UV filters than there are on dogs in campgrounds.
โJan-15-2015 05:00 PM
monkey44 wrote:
Might be the lens is not turned on AF -- if you accidentally flip the lens MF switch, it will not focus and all your photos will be blurred.
One other issue: Check your contacts - lens to camera. If those get dirty (and they do over time) a little contact cleaning will do wonders for the communication between lens and camera.
โJan-15-2015 12:10 PM
โJan-01-2015 02:28 PM
WyoTraveler wrote:the bear II wrote:
I had a professional video business for over 30 years. About every 3-5 years my video cameras would begin to have what looked like a blur to the videos. I tried having the cameras cleaned by the factory but the problem wouldn't go away. This happened with 3 different cameras over the years. I ended up replacing the cameras.
My guess is the sensors/electronics get out of alignment due to age and use.
However, Cannon replaced everything in mine for free. It is hetter than my new Minolta camera now.
โDec-31-2014 12:22 AM
โDec-30-2014 04:42 PM
โDec-29-2014 05:59 PM
โDec-29-2014 10:57 AM
โDec-29-2014 10:38 AM
