I got the followin from a Garmin Support Rep:
KANA IQ
Both the Camper/RV 760 and the Camper/RV 660 have the following features:
Custom RV Routing1
Directory of RV Parks and Services
Lifetime Maps
Lifetime Traffic
Voice-Activated Navigation
Bluetooth Compatible
Active Lane Guidance
photoReal Junction View
Bird's Eye Junction View
Smartphone Link Compatible
Direct Access
Displays your current speed and the Speed Limit
Points of Interest
Up Ahead Services
School Zone Warnings
Garmin Real Directions
Garmin Real Voice
The Camper/RV 660 adds the following features:
Elevation Profile
Easy Route Shaping
BC 30 Wireless Backup Camera Compatible
Screen Size:
The Camper/RV 660 has a 6" screen
The Camper/RV 760 has a 7" screen
Garmin | Customer Support + Get Help
What is Easy Route Shaping and how do I use it?
This article only applies to the Camper/RV 660, dezl 570, dezl 770, dezlCam, Garmin Drive series, Garmin DriveAssist 50, Garmin DriveLuxe 50, Garmin DriveSmart series, and nuviCam.
The calculated route can be manually shaped to change its course. Adding a shaping point will allow the calculated route to take a certain road or through a certain area without adding a via point or destination to the route.
To manually shape the route:
While in a route, touch anywhere on the map
Touch
Select a location on the map
Allow the route time to calculate
Touch the map again to add another location
When you have finished shaping the route, touch Go!
This will shape the route to the way you want it to go. You can add up to 30 shaping points to your route.
Chris and Pat
2023 Ram 3500 Limited, Cummins, Aisin, dually, Auto Flex Rear Air Ride Suspension
2022 Grand Design Reflection 303RLS
2024 Winnebago Minnie 2327TB
