Dec-27-2016 02:56 PM
Dec-30-2016 05:39 AM
gemert wrote:
Ulvik, sorry if I sounded a little testy, didn't really mean it. I used an old iPhone 5 that I just use with WIFI. I have netflix. I hooked the cable to the phone and plugged it directly into the TV HDMI connector. I ran a movie on netflix on the phone and it was mirrored on the TV. I'm not an expert but it worked for me. Good luck on getting it to work for you. FYI, I normally just cast it to the TV using Netflix. I probably won't ever use it, just keeping as an option.
Dec-30-2016 05:10 AM
Dec-30-2016 12:08 AM
Dec-29-2016 09:05 PM
Dec-29-2016 03:25 PM
Bucky Badger wrote:ulvik wrote:Bucky Badger wrote:ulvik wrote:Bucky Badger wrote:ulvik wrote:
Will not work at all from your phone or tablet to TV. It will not transmit over because of a block. Trust me I tried everything.
Did you try an Android device? Mine works fine
No regretfully I have an IPhone. But you said you can use the directtv app on Android definitely correct? I want to do this because the direct tv app does not use my data.
I shot this video this morning. Sorry I had the tv muted
https://www.youtube.com/watch?v=cy8oJgf7aaw
Thank you very much if you don't mind me asking what phone are you using? Looks like it is time for a new phone! Thank you again. Also I noticed you shot the video at home but this will work on the road when WIfI is not available correct?
I have an LGG4. Can't answer if it will work on the road at this time
Dec-29-2016 03:11 PM
jeffo wrote:
I watched gemert's youtube video and all I saw was commercials. Mine would work on the commercials both not on the actual program. Believe me it's blocked.
Dec-29-2016 02:56 PM
Dec-29-2016 08:32 AM
hpdrver wrote:
I got to amend my previous post because I hooked up my iPhone 6 via hdmi cable to my tv and I could not get picture but did get sound. Some block must be in the app. Has anyone had success by streaming via Apple TV.
Dec-29-2016 06:45 AM
Dec-29-2016 04:44 AM
Dec-29-2016 04:28 AM
Dec-28-2016 06:36 PM
gemert wrote:ulvik wrote:Bucky Badger wrote:ulvik wrote:Bucky Badger wrote:ulvik wrote:
As I said earlier, the iPhone works! WIFI is not involved in the transmission to the TV, just the cable. Just buy the cable from Amazon. I'm not going to make you a video, believe it or not! Your call.
Dec-28-2016 06:28 PM
Dec-28-2016 06:02 PM
