โJun-14-2013 02:49 PM
โJun-15-2013 10:34 PM
โJun-15-2013 08:58 PM
docj wrote:
I think it's the underlying reason why the Ranger told the OP "iPads won't work here". It sounds as if the Ranger has had experience with other irate campers who couldn't get on the wifi. If he knows that iPads won't connect it is probably the result of WMM not being enabled on his router.
If the OP had a problem in addition to this it's kind of irrelevant if he wouldn't have been able to connect anyway.
โJun-15-2013 07:17 PM
1492 wrote:docj wrote:
wrote:
For those who doubt that the WMM issue can prevent an iPad from connecting to a particular router I provide the following from the Apple support website.
But there's a difference between connection and detection issues. I've never heard of WMM causing a WiFi signal to not be discoverable? Which is the issue the OP is apparently having, so still don't see how WMM is applicable in this instance?
โJun-15-2013 06:19 PM
โJun-15-2013 05:50 PM
Davydd wrote:Cajun Bill wrote:
I wish I was still there to try some of the recommendations, but at home now. As info, I noticed that the wifi antenna was two sites over (about 75 ft. max) so I'm guessing that was close enough. The ipad did not give any indication of even sensing the signal (you know, the little antenna designation that pulses), but my Iphone did see the signal, but as far as I could tell, I was accessing the "net" via 3G rather than over the wifi. Guess I need to get a little more "edjumacated" before I can ask intelligent enough questions to solve this problem. Anyway, glad to hear that at least some others have had this same problem and thanks for the comments.
What I read is you are looking at the menu bar for the wifi detection signal to come up. It works that way on a Mac but not an iPad. If your iPad has never been on that network before, you have to go into the Settings app and first make sure you have wifi turned on to detect a signal. Then you have to select the network you want to connect to. You might be surprised in a campground how many private ones might be set up by other RVers. Click on the one you want. Some might be password protected even if free and you may have to get that password from the office. Often they are not password protected but you might have to wait for a user agreement to come up and click on an agree button. I camped in three Louisiana State Parks this spring and got on with my iPad. One did disable video which severely limited use, IMO, but not all did. I was still able to connect.
โJun-15-2013 05:27 PM
โJun-15-2013 05:12 PM
โJun-15-2013 04:47 PM
โJun-15-2013 12:37 PM
โJun-15-2013 12:25 PM
โJun-15-2013 09:54 AM
1492 wrote:
I'm not clear as to whether the OP meant cannot find as not being able to see the WiFi SSID? Or not being able to connect? Might help to install a WiFi sniffer app in your iPAD. I use WiFi Analyzer in my Android Smartphones, but not familiar with similar apps for Apple mobile devices? Would give general info about WiFi signal strengths and encryption used.
โJun-15-2013 09:17 AM
โJun-15-2013 08:21 AM
โJun-14-2013 08:22 PM
There is a huge amount of misinformation in this thread. You don't have anything wrong with your iPad and neither is there anything "wrong" with the router.
The wifi problem being experienced by iPad running iOS6 results from Apple having implemented a protocol known as WMM....
You may be right about that, except that I believe Apple has implemented WMM since at least iOS4.x. It's not new to iOS6. Or did Apple change something with the way they implement WMM in iOS6? Notwithstanding, if WMM is the issue in this case, then not sure how deleting/creating a new WiFi profile if WMM is not enabled in the Park's router in the first place, would not be a moot point?
I would have doubts that WMM is the only iPad WiFi related issue. Considering some owners pointing to WPA2/AES specific connection problems, but working fine with other encryption protocols. And that Apple has apparently been replacing customers mobile devices who complain about this connection issue. I don't see why they would do this if it was a router based issue, since a replacement would experience the same problems? :h
