โNov-27-2013 03:32 PM
โJan-16-2014 07:18 AM
โJan-16-2014 05:26 AM
jdog wrote:transmitters are not necessarilly all in the same direction.
Why would you want to move the direction of the antenna searching for an unknown channel when you are receiving in the present location?
โJan-16-2014 03:24 AM
โNov-29-2013 07:50 PM
โNov-29-2013 07:22 PM
โNov-29-2013 06:04 AM
โNov-28-2013 04:22 PM
โNov-28-2013 03:14 PM
Dutch_12078 wrote:Ditto..SCVJeff wrote:
There are two reasons to switch to a Jack:
- It points in the same direction as the pointer in the cab
About 10 seconds work with a Sharpie took care of the pointer confusion on my Sensar III dial. :B
ScottG wrote:It is that cut and dry and I beat you to it. Read This.SCVJeff wrote:
- It fits in a footprint that the batwing can't.
But performance wise it cannot match that of a working Batwing. Between the two, the Jack lacks performance arcoss the entire band
This has been argued to death around here and it's just not that cut and dry.
I suggest the OP do some research on the subject if he's not already convinced.
But FWIW, In my own case I get twice the number of stations with my Jack here at home.
Next season I will run both so I can compare them side by side.
โNov-28-2013 02:34 PM
โNov-28-2013 02:16 PM
โNov-28-2013 11:25 AM
โNov-28-2013 09:36 AM
โNov-28-2013 03:34 AM
Bob Vaughn wrote:
I am wondering is the Jack antenna head will fit in place of the bat wing on my Antenna Tek antenna?
