โMay-19-2015 07:35 PM
โJun-25-2015 07:05 AM
SCVJeff wrote:
Should I tell you how good it was ? ๐
โJun-23-2015 02:05 PM
โJun-23-2015 12:38 PM
โJun-23-2015 11:14 AM
โJun-22-2015 03:32 PM
โJun-22-2015 08:39 AM
โJun-12-2015 08:52 PM
โJun-12-2015 06:55 PM
โJun-12-2015 05:51 PM
โJun-07-2015 08:33 AM
โJun-07-2015 08:29 AM
Tom_M wrote:
If you are having reception problems the first thing to do is to determine where the problem lies.
First, make sure you are pointing the antenna in the right direction. The arrow on the knob does not point to the front of the antenna. The arrow is for positioning the antenna for stowing. If the arrow is pointing north the antenna is facing either east or west.
Most problems are not the antenna but the wiring. Check all the coax for:Make sure that there is power getting to the antenna. While you are on the roof, disconnect the coax from the antenna and check that there is 12 volts present.
- Loose fittings
- Corroded connections
- Cracked or cut outer covering
If some channels are good but others bad, you may benefit from adding the Wingman attachment. Make sure the antenna will stow okay with the Wingman attached. Or you could replace the head with the Sensar IV which has the Wingman built in. Prices are $25 > $30 for the Wingman. $50 > $60 for the Sensar IV head.
Here's a link to a good article on tuning up your antenna:
Tune up your antenna
The general consensus is that the Winegard Sensar is the best RV antenna, especially for VHF. In the U.S. about 25% of the full power stations are VHF.
โJun-07-2015 06:35 AM
โJun-07-2015 12:32 AM
MNtundraRet wrote:i havent actually experienced it out of Cal, but i see the potential for the problem almost anywhere i go for business, and i think the problem could be worse in the flatlands where you may have TV antenna farm in one or two places, but i see FM transmitters scattered all over the landscape, and don't forget, unless filtered (and they're not), FM transmitters can saturate the amps often easier than the TV xmtrs can. At least you have THAT list. The Phoenix to Tucson corridor is a perfect example where you may have the main antenna farm on South Mtn., Lemon, etc. In PHX and southbound there are full power FM transmitters scattered on both hilltops and tall towers all over the place. Wish i knew how to spot and fix these so the deep frings amps don't get creamed. Anyway that was an FYI because it bit me and I know better.SCVJeff wrote:
Careful about running gain that hard inless youre working your way up beforehand or it can get ya and you wont even know it. Where we typically camp there is a comm site several miles away that i think has at least one FM up there, and thats enough to swamp the TV, or maybe the amp with the RF coming off the hill. Im pointing away from there and could use some extra help, but the FM kills the amp
The only places I have been were near by signals could overload was Loveland, CO with the transmitter above the town on the mountain. I only used the 10 DB Winegard amp with the Winegard antenna stored on the roof.
Other locations are on Lake Superior, or Lake Michigan, where the lake conditions can increase signals received, There the one amp, or maybe 2 DB gain on 2nd amp will do.
What usually happens is the close in signal is never found during search because of overload. I have missed some channels coming from Duluth at Ashland, WI. Lowering the additional gain to 2 to 4 DB will finally locate and store channel in the TV's memory.
I carry channel lists from 2 sources to identify transmitters I expect to receive signals from.
I would expect the problems you talk about to be mainly a California issue do to all the foot-hills and different cities in close proximity broadcasting. That's what I call unwanted signal bounce coming off sides of hills causing unwanted interference.
โJun-06-2015 09:01 PM
โJun-06-2015 08:53 PM
IAMICHABOD wrote:Tom_M wrote:IAMICHABOD wrote:How many channels do you get with the Rayzar?
So I opted to put a Jack on and my channel scan went up to 60
About 9 at the campground that I tested both of them, the thing is, I got them off the backside of the Rayzar,so I was getting them from a different set of towers.
