Apr-30-2022 07:00 AM
May-06-2022 12:25 PM
ccjack wrote:brholt wrote:ccjack wrote:
I am new to RVing and have a question on wi-fi. Our new TT came with a Winegard air 360+. My understanding is it is a HD TV antenna but also has wi-fi router capability. We would need to purchase an additional gaetway router that installs inside the RV for $300. My question is what does this do? The air360+ pulls a wifi signal from the campground (as an example - the campground would provide log in info?) and then the $300 router serves as a booster for the area around our individual TT? Can't you just use the campground wifi without a router?
This is unrelated to any co-ax cable connectors on the outside of the TT, correct? The Winegard is not connected to any coax cable in the TT correct?
I am a bit confused as to what we should buy or not.
thanks.
We have the Air360+ and the Gateway modem. The Gateway unit adds additional antennas for both wifi and cellular signals. Our experience is that:
- TV reception is not pretty good but do not expect it to compete with directional antennas.
- WiFi is able to pull in signals our iPhones can not but most campground wifi isn’t very good.
- We have been impressed with the ability to grab cell signals. As an example, we were at a harvest host farm who claimed they had not been able to get cell service but we were able to get AT&T. This has repeatedly been our experience. I attribute it to the multiple antennas and the rooftop location. Note that I believe the Gateway is only a cat4 modem so it is never supper fast. WiFi Ranger sells their Osprey unit to go with the Air360+ which can be obtained as cat6 or cat12 units so they may be much faster though I don’t know if the Osprey adds antennas like the Gateway does.
Overall we have been pleased with the unit and it has given us data in a wide variety of place our phones have not been able to.
thank you all for the responses, they are helpful. One question about the Osprey vs. Gateway. My understanding is the antennas are already in the Air360+ and they are just not active unless you add the gateway. So is it possible the Osprey would offer faster wifi plus utilize the wifi antennas already in the 360+ I am not sure of the wiring and hookup for the Osprey... thanks.
May-06-2022 06:16 AM
May-06-2022 05:19 AM
thanks.
May-05-2022 01:48 PM
thanks.
May-01-2022 12:28 PM
Wade44 wrote:
Add to all that the Winegard 360+ totally sucks as a HDTV antenna unless you're basically parked within 10 miles of the broadcast point. Its a piece of junk.
May-01-2022 07:06 AM
Apr-30-2022 05:02 PM
Apr-30-2022 03:47 PM
thanks.
When in doubt, read the manual..
FOUND HERE
Right on the very first page it says..
"WINEGARD AIR OMNIDIRECTIONAL TV/FM ANTENNA + WIFI + 4G EXTENDER*
*WiFi & 4G functionality requires Winegard Model AR-360B 360+ Gateway (GW-1000) sold separately"
Page 4 states..
"Winegard recommends installing the Gateway directly under the Air 360 + . Once the Air 360 + has been installed, there are two requirements to finding a location on the RV ceiling for installation: +12VDC must be present, and the three WiFi/4G antenna cables from the Air 360 + must be able to reach the connection points on the Gateway router."
Additionally, you might wish to read the Gateway GW-1000 manual for more details on setup and operation..
FOUND HERE
Apr-30-2022 02:54 PM
thanks.
Apr-30-2022 11:06 AM
Apr-30-2022 09:26 AM
Apr-30-2022 07:48 AM
