Apr-08-2017 06:15 AM
Apr-08-2017 01:39 PM
Verizon Wireless
Verizon Wireless was the first to arrive to the 4G LTE race and it has also built its nationwide network based on 700 MHz spectrum, but the primary band for Verizon is band 13. Bands 2 and 4 are used to strengthen the signal in the densely populated urban areas. One important thing to note about Verizon Wireless is that many phones are built specifically for the carrier, including its 4G LTE bands.
Apr-08-2017 10:32 AM
mr. Wizzard wrote:
have you tried the yagi on sleek
Mr. Wizard wrote:
Are you trying to get LTE data on a 3G sleek, that won't work
The lte models are backward compatible to 3G and 1x, but the 3G models are not tuned to LTE and can not pick it up
Apr-08-2017 09:13 AM
Apr-08-2017 09:09 AM
Apr-08-2017 08:46 AM
I was thinking of using a yagi or Trucker, which has its own ground plane.
Apr-08-2017 08:06 AM
Fred_n_Jo wrote:
Verizon's answer to that question is on this page, scroll down to the Q/A section
https://www.verizonwireless.com/internet-devices/jetpack-mifi-6620l/
Yes it does have an antenna port.
It is on top same side as power switch. The cover is a little difficult. Just lift straight up.
I glued a 12 inch pie plate with dicor on the roof of my trailer.
The pie plate was grounded to the trailer frame.
Thus the pie plate serves as a magnetic base for my magnetic antenna and a ground plane for the antenna.
It does work with a significant increase in signal strength.
My 5th wheel has the groilla cage aluminum frame which is not good for radio signals inside the trailer.
Search for antenna adaptors and antennas for the 6620L.
Apr-08-2017 08:02 AM
Apr-08-2017 07:53 AM
Apr-08-2017 07:12 AM
mikestock wrote:I suspect all of the Antennas you are talking about for these units will use the WILSON SLEEK idea of close proximity - no actual antenna connection.
Then why do they make an antenna adapter for the 6620L?
I have a Sleek and am not that impressed. Of course, I'm looking for 4G, not 3G. I'm sure that makes a difference. My goal is 4+ mb/sec download.
Apr-08-2017 07:04 AM
Apr-08-2017 06:55 AM
Apr-08-2017 06:51 AM
Apr-08-2017 06:39 AM
