Satellite internet access
Lwosten
Some parks have poor or no 4g/3g phone access so a phone cant be used to access the internet and/or be a hotspot . So a satellite is a good solution for internet access I assume I called Hughsnet and they said they can not guaranty a good 2 way connection if i aim the satellite myself they say if i try and dont get it aimed just right it will burn out the "arm" and require a $400 repair. Apparently 2-way communication required for satellites used for internet have to be aimed exactly, unlike satellites used for tv which are only 1way communication
So what is the option people use to get internet access in places with no/poor phone service
Thanks, Bill O
14 REPLIES 14
TechWriter
paulcardoza wrote:
I guess it all depends on one's performance/cost expectations......
If the choice is between no Internet or slow Internet via sat dish, I expect that I'd choose the latter.
BTW, I keep a tripod HughesNET system handy for those occasions.
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
paulcardoza
Bill.Satellite wrote:
paulcardoza wrote:
Satellite Internet is a terrible option, unfortunately. If those CG's you refer to have poor cellular service, maybe some type of external cellular antenna/booster will get you acceptable cellular service. If there's no service at all and you MUST have internet, your probably better off finding somewhere else to go.
That's simply not true. Satellite internet is still an excellent solution when no other service is available. It's also an excellent solution is you are a US citizen and like to travel to Mexico or Canada where cellular service can be extremely expensive. I ran a business for over 10 years using the Hughes HN7000 service. I could do everything I needed on the internet. I often had better service than what the campgrounds were providing with their free wifi. No, it's not as good as a good cellular connection but with speeds around 150K up and 1.5 MB down it is a very usable service.
Paul & Sandra
Plymouth, MA
2014 Heartland Cyclone 4100 King
Bill_Satellite
wa8yxm wrote:
First there is a company that makes dishes for Hughes 2-way Satellite that aim themselves.. RF-Mogul as I recall but memory is fuzzy.
MotoSAT used to make the Datastorm for satellite internet but they are now out of business and while RF Mogul is run by the former owners of MotoSAT, they do not build the Datastorm or any other satellite internet antennas. There are still some used Datastorms out there for sale but they are no longer built.
Winegard builds an internet dish as well as a couple of smaller providers.
Can't we all just get along?
Bill_Satellite
wa8yxm
Two answers:
Used to be Motosat did that, this company is made up from ex Motosat folks.
Second, even if you get a manual dish, Using the tools provided in the manner your installer will train you to do (Takes like 30 minutes) you will do a professional job of aiming.
I will describe the basic procedure.
First go to your MODEM and access it, Feed it your Lat and Long (From your GPS) and it will give you some numbers, Azmuth, Elevation and Skew,, Write 'em down.. NOTE: there are computer programs that can do that for you as well.
Now UNPLUG the modem and hook things up. Make sure the mast for the antenna is PLUMB. (Straight up and down)
Pre-set elevation and SKEW on the dish.
Plug in and access the modem from your laptop.. or smart phone, Set it to "AIM" (Not the actual menu choice but you get the idea)
Slowly swing the antenna through the azmuth (Direction) indicated till the meter peaks... When you peak play a bit with elevation to maximize the peak, NOTE, these may interact so re-check direction.
Switch to the 2nd aim mode.
Adjust the SKEW to peak that reading.
Lock it down
Unplug modem
Remove in-line meter
Plug back in
NOTE: be sure to tell the modem where you are.. IF you fail to do this it may not work properly. This is part of the set up menu tree.
paulcardoza
Thanks, Bill O
Paul & Sandra
Plymouth, MA
RFCN2
Bill.satellite summed up the current situation with sat internet pretty well. I have a Motosat F1 internet dish on top of our motorhome that aims at the satellite automatically, most of the time. It does work anywhere. But the speed is slow. I tried to increase the speed about two months ago and they said I could not, so I did not renew the service. The speed is normally more than 1/10th as fast as 3G, but it is usually slower than 3G. All the internet services speed is dependent on how many users on it. If they wanted to Huges could give lightening fast sat internet, but they don't want to at this time. So could Via Sat, which is another high speed provider. We could get very high speed sat internet at our house, but not at our motorhome.
If you absolutely have to have internet connection get a satellite internet dish. If your need is less than that get a good smart phone with a hot spot feature. I personally use Verizon which has good coverage. Not everywhere though.
RFCN2
Country Coach
Jeep Wrangler Unlimited
amandasgramma
Just a little note here.....we have Verizon cell phone service and AT&T MiFi...... why 2 different ones, I don't know (sigh). BUT, we've been traveling down the east side of Utah and now in Quartzsite, Az......in all, we've had wonderful service on the internet (4G with 4 bars).....even when we didn't have good cell phone coverage! 🙂
My mind is a garden. My thoughts are the seeds. My harvest will be either flower or weeds
Dee and Bob
plus 2 spoiled cats
On the road FULL-TIME.......see ya there, my friend
2oldman
Take a drive to somewhere that does.
Bill_Satellite
The current Hughesnet satellite internet service in not mobile at all so forget about that (the Gen4 service). However, the older Hughesnet service which uses the HN7000S modem is still a workable and usable service that will not be damaged in any way if the antenna is not properly pointed. If it's not properly point you just can't get online. The service is fairly slow but way better than nothing at all and the equipment required is large and bulky but easy enough to deal with with a bit of practice. Plan to pay $60-$80/month with a 2 year contract for service that is 1/10 the speed of 3G cellular and complete incomparable to 4G.
Hiking_Hunter
Try one of these before you give up on cell phone 3g/4g service. We just finished an across the country trip taking 10 1/2 weeks - probably 30 campgrounds. We always had cell service, and were only without internet service 2-3 times.
Best Buy has a less expensive version of the Wilson Sleek. I've seen it as low as $79. Be sure you get the correct one for the service carrier you have. We were using Verizon and used an iPhone for a hotspot. Used and iPad and a laptop.
Amateur Radio WA4GIY
2015 Montana High Country 305RL
2013 RAM 3500 4x4, crew cab, long bed, 6.7 CTD, Aisin trans.
CGVW 20460 Lbs.
rv2go
There are lots of Hughes net tripod users. I suggest you visit the Tripod User's forum. Scroll down 6.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
pronstar
No 3G/4G phone service means we get no internet...or phone calls from the office.
And I'm perfectly OK with that.
'07 Ram 5.9 QC/LB SRW
Full Carli Suspension
35" Toyo's | 4.56 | PacBrake
2009 Cyclone 3950 | B&W Turnover Ball & Companion | TrailAire | Duravis R250s
DutchmenSport
It's really not an option at all. We throw another log on the fire and eat another hot-dog, and listen to the crackling of the fire and crickets.
