Unknown Data Use
Dog_Folks
I am only marginally computer savvy, so I need some help.
I have ATT USB plug in for my internet access.
In the past few days I have noticed theta on my device and on my ATT on screen internet manager, there is a download and an up load going on on almost continuously, even when the browser is not connected. (it shows up load and downloading with a symbol)
It is using about 1GB a DAY in data!
How can I find out what is doing this and stop it?
Please keep your answers simple, for I am nowhere near a geek.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
34 REPLIES 34
1492
Moderator
Moderator
bwanshoom wrote:
Did you try Resource Monitor to find out which program is causing the network usage?
Make sure to click the "Network" tab.
1492
Moderator
Moderator
What version of Windows-Home Premium, Pro, etc? Is is 64 bit?
You don't need to uninstall Dropbox. Just right-click the Dropbox system tray icon. Click the tool symbol, and select Exit Dropbox. Or just go into preferences, and disable auto start-up to use Dropbox on demand when you need it.
bwanshoom
Dog Folks wrote:
jcpainter wrote:
Any chance you are using Carbonite or similar online backup program?
If so, turn it off when using your cellular data.
Nope
2010 Cougar 322 QBS
2008 Chevy Silverado 2500HD LMM CC/SB 4x4 LTZ
Pullrite SuperGlide 18K
Bill_Satellite
Dog Folks wrote:
OP HERE UPDATE--
Just in the short time that I have first posted data use has been .8 GB Help!!!
Yes, I am using a ATT Sierra Beam.
Drop box removed form computer---No effect. High data usage still occurring.
Restore to 4 days earlier. High data usage still occurring.
Malware byte's scan presently running.
If you have a smartphone(s) check those as well as any photos you have there can be send to the cloud as well. If possible, go to an ATT store now and have them find out what's going on. You can start looking my shutting one device down at a time and see when the usage stops.
What are you using to monitor your usage? Something from AT&T or something like NetMeter?
Can't we all just get along?
Dog_Folks
Nope
Our Rig:
jcpainter
bwanshoom
Run Windows Resource Monitor (enter "resmon" in the Start Menu search bar). Click on the Network tab and it will show you how much data is being sent/received by each processes. That may help you narrow down the culprit. Then search on the name of the process that's sending the most data to find out what program it is.
2010 Cougar 322 QBS
Dog_Folks
E-mail password changed, computer restarted, just in case. NO effect.
Our Rig:
tonyandkaren
It's also possible that your email account has been hijacked and someone is using it to send out tons of spam. Change your password if you suspect this.
Our Fulltiming Blog
Clickable Attractions Maps
4x4 Custom Class C on F450 chassis
tonyandkaren
To find if things are running in the background -
Open your Start Menu. In the search box enter - msconfig Click enter. Click "Continue" In the popup box click on "Startup" This will show all of the programs that are turned on when your computer is running. A lot of them are necessary but many are not. Be careful about what you click off. We have about ten that must be on and about 15 that we have turned off on startup- like Itunes, windows live messenger, quicktime. These run fine when we need the programs and don't have to be on all of the time.
Turn of all of your automatic updates. Go to security for Windows Updates and turn it off. Download updates when you have WiFi. Check all of your other programs and turn off updates.
Our Fulltiming Blog
Dog_Folks
HappyKayakers wrote:
Tell us more about your PC. Is it Win 8 with live tiles by any chance? Couple of other culprits are Facebook with automatic video load and other websites that autoload videos.
You said that data usage was happening even with browser closed. If that's true then you should be able to open Task Manager and see which processes are active. One of them may be to blame.
Using a Toshiba Satellite with Windows 7.
I do visit Facebook at least daily. If there are auto loads, how do I shut that off?
Malware scan complete. No change. Data use still running out of control.
Using task manger, how would I spot the usage? I would not know which process to delete?
Thanks for all your help. It is appreciated.
Our Rig:
HappyKayakers
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Dog_Folks
OP HERE UPDATE--
Our Rig:
amandasgramma
ditto what others say -- we have 10 gb with ATT and always always turn it AND the computer off when we're not using it. ๐Ÿ™‚
My mind is a garden. My thoughts are the seeds. My harvest will be either flower or weeds
Dee and Bob
plus 2 spoiled cats
On the road FULL-TIME.......see ya there, my friend
Bill_Satellite
I did not think I used any cloud services either until my data usage went nuts. Much like you describe. I finally discovered that I had downloaded Dropbox so I could transfer a large file to someone. It was to large to e-mail. After that, dropbox started uploading all my files and pictures to "my cloud". It was weeks later and over 20GB before I happened to open the dropbox program and found my stuff there.
