Vista Upgrade to Win10?
RetiredBob
I have an older desktop running Vista that we only rarely use (I have a laptop, wife has an Ipad). I want to keep it as a backup and for occasional tasks that are easier on the desktop. I don't think MS is offering the free Win10 upgrade for Vista. My question is, should I purchase and upgrade to Win7 and then upgrade to Win10 when available, or just leave things the way they are? I've had no problems with Vista to date.
47 REPLIES 47
MrWizard
Moderator
Moderator
IMO if you could get "drivers" for all the internal hardware
XP would run circles around win 8.1 .. on the same PC
I can explain it to you.
1997 F53 Bounder 36s
8_1_Van
bcsdguy wrote:
Install xp on your new computer after wiping out that damn 8.
I would wait a month and install Windows 10 for free before going back to a 13 year old OS with zero support from Microsoft.
MrWizard
Moderator
Moderator
Great ..thank you
AllegroD
Nice, strollin. Thanks.
strollin
MrWizard wrote:
Strollin
I'll try that..thank you
It works in Win 7 & Win 10 as well.
Me, her, 2 boys & 2 girls
'05 Chevy 2500HD LT 4x4, D/A
Reese Dual Cam HP
'04 Wilderness Advantage 290FLS
Twin Honda 2000s
"I'd rather wear out than rust out!"
See our pics here
MrWizard
Moderator
Moderator
Strollin
docj
strollin wrote:
What a complete Programs menu of ALL of your installed programs without a 3rd party app?
Right-click on Taskbar, select Toolbars->New Toolbar...
Put "%programdata%\microsoft\windows\start menu\programs" into the folder box (without quotes) and click "Select Folder" button. You'll now have a Programs toolbar on the Taskbar that has all of your installed programs listed on it. As you install new programs they will automatically show up in the menu.
Cute trick. My list is a bit long, but it's still useful. Thanks
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
strollin
Reese Dual Cam HP
Twin Honda 2000s
See our pics here
MrWizard
Moderator
Moderator
yes Da***** typing search is what i have been doing
BTW that Windows key plus "X"
only brings up the same limited menu that i get by moving the cursor to start and "right clicking"
nothing different nothing extra
thanks for the control panel ICON tip.. that helps
strollin
MrWizard wrote:
... want the calculator ? or Notepad ? no more windows accessorizes.. gotta search ...
Instead of fighting it, why not embrace Search in Win 8.1? It can find things very quickly. On my 8.1 machine, searching for calculator, by the time I've typed "ca", it's already located it, doubt I could find it in the Win 7 Start menu any faster. Same with notepad, I type "no" and it's located it already.
bwanshoom wrote:
strollin wrote:
AllegroD wrote:
The pop up menu is back in 10. You won't need Classic Shell.
It cracks me up when I see someone say the Start menu is back in Win 10. The Start menu in Win 10 is more or less a windowed version of Win 8.x's Start screen. The tiles are still there and the apps are still there, the only thing that changed is that the menu isn't full-screen.
I think that might be a bit of an oversimplification. It's not the same as Win7, but it's not just that it isn't full-screen.
Somewhat simplified, yes, that's why I said "more or less". It isn't that big of a departure.
Reese Dual Cam HP
Twin Honda 2000s
See our pics here
bwanshoom
2010 Cougar 322 QBS
2008 Chevy Silverado 2500HD LMM CC/SB 4x4 LTZ
Pullrite SuperGlide 18K
docj
MrWizard wrote:
after 9 full days of usage/frustration.. i'm ready to install classic shell
It does get easier with time. I have two Windows 8.1 laptops one of which I've had ~2 years and I no longer bother to run Classic Start.
A couple of things that you might not yet have discovered:
--The hidden menu that pops up with the "Windows key + x" is one I rely on a lot.
--Configuring my touchpad to prevent the "charms menu" from appearing except when I want it can greatly reduce your frustration level.
--Configuring the Control Panel to display large or small icons rather than categories makes it a lot easier to use.
And BTW, the Restore stuff is in the Control Panel under the Recovery icon once you reconfigure it.
Don't count on Windows 10 until you check to see if your computer can be upgraded. I've already identified potential problems with mine (my Intel HD4600 display, in particular).
Joel (AKA docj)
Sandie & Joel
MrWizard
Moderator
Moderator
my new replacement PC has win 8.1
that popup so called start menu provides about half of what XP/win7/classic-shell provides
even the control panel sucks
want system restore.. you have to do a search, its not in the control panel choices
want programs folder/directory .. gotta go thru my pc/windows/ etc..
install a new program ? no quick link in the menu
8.1 start menu is joke..
strollin
Reese Dual Cam HP
Twin Honda 2000s
See our pics here
