Wi fi extender
buc1980
I like to install a WI fi extender(buster)in my FW.I see some but I don't know if they work good.Which one is better and easy to install.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
7 REPLIES 7
theoldwizard1
The best WiFi extender is GOOD antenna. The best antennas are directional so you might need some kind of of "strength" meter to "dial in" the antenna direction. Many WiFi antennas come with an amplifier, but I don't think and amplifier is that important.
The problem is laptops do not have an external antenna connection. Either you need a USB WiFi adapter.
Google "WiFi range extender" and you will find several recent reviews.
BobKrogstie
On the JEFA Tech WiFi Repeater System XR setup it's a matter of "read a line, turn a screw".
Bob and Natalie
2008 Grand Junction 37QSB
2009 Dodge 3500DRW Big Horn 4X2/CC/LB/CTD/4:10/Auto
shastagary
they all have to be reconfigured or set up at each place you want to extend the wifi at. some are a little easier than others to set up they are not just plug and play unless you go to the same place each time.
wa8yxm
Simplest is Wi-Fi Ranger.. But there are other ways.
If you know where to point it a directional antenna helps.
Lwiddis
I need one, buc. Let us know how whatever you install does.
BobKrogstie
I use the JEFA-REPEATER-XR - JEFA Tech WiFi Repeater System XR and am happy with its performance and ease of installation.
Bob and Natalie
mikebreeze
I have been casually looking for a wifi extender myself. I have been getting email newsletters from
www.technorv.com
and he has a interesting selection of them.
2006 Four Winds Majestic 23A
