WiFi Range Extender
winnehonda
What seems to work the best, for a reasonable price, to extend wifi reception in my Class A?
Mark Hanlon
26 REPLIES 26
pconroy328
1492 wrote:
DutchmenSport wrote:
We looked into getting a Netgear WIFI extender for the house. We went to Best Buy and talked to the folks there. The guy who helped us explained, that even though the range of WIFI is extended, the upload and download speed was considerably reduced ... like 50%. Thats no problem if you are using static web pages, but for streaming video or gaming, it could cause too much of a slow down.
Well, the guy is painting some broad strokes and leaving out some details? The speed reduction is the result of the "single-radio" having to do double duty by receiving and re-transmitting the signal. In fact, it will likely be even more than a 50% reduction in data thoughtput? It's very device dependent. Though claimed WiFi device bandwidth speeds tend to be already exaggerated.
Just note that the reduction is WiFi bandwidth. Not necessarily in internet access speeds. If your connection speed to the internet is already low, what you'll likely experience using a campground connection, then you may not experience any appreciable downgrade by using a repeater.
My internet bandwidth connection was so low at one point, about 4.8Mbps down connecting directly to my WiFi router, that when I connected to my WiFi repeater, my speed was still 4.5Mbps. Not a 50% reduction so many claim? My old repeater WiFi speeds was about 24Mbps max, so well above my internet connection speeds even if you take the 50%+ reduction in WiFi bandwidth into account.
BTW, they do make dual-radio repeaters that should result in minimal WiFi bandwidth loss. It all depends whether you would benefit from it as it is dependent on your internet connection speeds in the first place?
Thank you for the sane response!
The irony is that I don't see the OP has returned to this thread at all. ๐Ÿ™‚
We really need to know what the OP wants to extend. Odds are they want to increase their ability to pull in distant WiFi signals.
We don't know for sure - as their post is ambiguous.
1492
Moderator
Moderator
paulcardoza
Frankly, for that price, the unit seems to offer few features. There's no wifi-as-wan options, no options to tether a mobile hotspot and have the unit select the best (fastest throughput) signal. All manual connectivity...... There are much better options out there, for similar pricing. e.g. WifiRanger.com
usersmanual wrote:
http://www.winegard.com/connect?q=internet&inf_contact_key=f0127d682f0f896753592b86d6d325511065ebdfb...
brand new out;; I wonder if its as good as advertised?
Paul & Sandra
Plymouth, MA
2014 Heartland Cyclone 4100 King
usersmanual
usersmanual
extend it from what ? and where to where?
jcpainter
APT wrote:
The OP needs to clarify what the goals are and what the current network topology is.
Absolutely!!! Without that information solutions may be being posted that are not appropriate to the problem.
sherlock62
Access points provide better wireless network bandwidth than range extenders, but an AP needs a wired connection to a router/switch.
I agree with this post versus the other crapola being posted in this thread. And as I said, WiFi Extension devices are not perfect but do the deed so to speak for some people.
APT
2017 Subaru Outback 3.6R
usersmanual
sherlock62 wrote:
Like many forum threads here, this thread has gone a muck so to speak. Regardless, do know that a WiFi Extender is a way to go if you need to extend a network. No, not a perfect solution, but it will more often then not, get very usable WiFi to an area where without the WiFi Extender, you would not have WiFi. I know quite a few people thrilled with their WiFi Extender. Sure worth a try for those with WiFi dead spots in a dwelling.
To "usermanual" you would do far better posting a link to the source of the crapola you post here. This way thread readers can read for themselves.
see DutchmenSport post ;;he posted the ""crapola"" I posted here with the actual ""crapola link""
hope thats more helpfull
DutchmenSport
sherlock62 wrote:
...To "usermanual" you would do far better posting a link to the source of the crapola you post here. This way thread readers can read for themselves.
I'll bite!
When to Use Your Range Extender
NETGEAR recommends that you connect to the range extender only when your home network connection is poor. Because data traffic routed through the range extender is inherently slower than traffic routed directly from the network, the computer should stay on the network if the connection is good enough. NETGEAR recommends that you connect
through the range extender network only when the computer is in a โ€œdead zoneโ€ where connection from the network is very poor or non-existent.
Chapter 1, page 5, "Getting Started" ... click here.
sherlock62
valhalla360
Nomad III
Nomad III
If you are able to tap into a campground WIFI and extend the range, then you better believe everyone else around you will be using the same signal from your extender too, slowing it down even more, as campground wifi's have the known reputation of running horrible when so many attempt to connect all at the same time.
Only if you leave the extender non-password protected.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
usersmanual
Fizz wrote:
usersmanual wrote:
I am not trying to tell you anything;; NETGEAR;; them selves very clearly state in the instructions that your response time will slow when using this product that's all I posted
This sounds like "A glass half empty" look on life.
My main router gets me 75 Mbps but I only get 4 Mbps at the far end of the house.
The Extender gets me 28 Mbps, it's not near the 75 but a heck of an increase over 4 Mbps.
You can look at it as a drop from 75, to me it's an increase from 4.
its not a look on life at all;; its what the company that make and sell claim;; they claim it will slow your computer down when using this item what part of that do u not understand
Bill_Satellite
Go here:
http://tiffinrvnetwork.com/forum/viewforum.php?f=111
and do a search for WiFi under $100 and you will come up with the link to David Bott's video on how to get a powerful connection for less than $100 (or a bit more for the upgrade which I highly recommend).
This IS IT!
Can't we all just get along?
