Wingard Video Distribution Center
CrossCountryMon
I have a Wingard Video Distribution Center model VS53DVD/VS5312D. It is wired direct with a 12V. However, when I try to power up the system, it does not come on. I checked the 12V hookup behind the system and it is inserted correctly. I followed the wire back as far as I could and all seemed to be ok. Please let me know if you have experienced this type of issue and possible "fix". Thanks! Frank
20 REPLIES 20
CrossCountryMon
Thanks for the great information. I will try to find the fuse this morning and check the coax cable. I will let you know how it works out. Again, thanks!
DJF
Yes, theres a fuse inside. Its tough to open so do it on a clean bench
fuse is just inside where the plug is located.
Bill_Satellite
Do you mean when you push the power button on the front the light does not come on? As mentioned above, the power needs to be on to watch OTA TV but the power button does nothing else to any other signal or button.
There should be a dedicated 7.5 DC amp fuse in the system so if you check the plug in the back of the controller and there is no power I would go look for the fuse. It's likely labeled TV antenna or TV boost or similar.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
enblethen
Here is manual. Look at troubleshooting area. Most have been covered by posters. One thing that could be a problem is a bad coaxial cable or bad antenna head.
Vs5312
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
sch911
The 12v is only used to power the Batwing antenna amplifier. Is that what's not operating correctly? Input source switching is a totally separate function of this device and should still function without 12V power.
OEM Auto Engineer- Embedded Software Team
gotsmart
next step would be to get a multimeter and confirm that the power wire going into the distribution center is actually supplying power - by checking it for 12V DC.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
