wyngard traveler
wacojim
I need to change sat #'s. Changing to dish. My control has power, select, and enter. I think it is sk1000. Hope someone can help. Jim
5 REPLIES 5
Bill_Satellite
If you are currently a DirecTV customer then the Winegard Trav'ler is either an SK-3005 or a newer SK-SWM3. The Winegard Trav'ler built for Dish Network is the SK-1000. If you are changing from DirecTV to Dish Network service the answers above about needing new hardware and someone to install it is accurate.
Can't we all just get along?
donn0128
It is Winegard. Contact Winegard next week and give them your current dish info and ask how much to convert.
wacojim
Forgot to mention I have a wyngard traveler.
jorbill2or
Yup some new parts on the roof .. about 300-400 bucks ??
Different satellite spacing requires a different setup .. be thankful a dish "traveler" can't be converted to directv .. requires a whole new $1400. 00 assembly
You can't change freely between dish and direct .. not with the winegard Traveler
Bill
accsys
Changing a Trav'ler from DTV to DISH requires a physical conversion process, not just a setup change in the controller. Some more information is available here.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
