Apr-14-2015 06:29 AM
Apr-16-2015 08:20 PM
Apr-16-2015 01:28 PM
Apr-15-2015 07:31 AM
Apr-14-2015 04:58 PM
mgirardo wrote:Drakensberg wrote:
I'm feeling quite daunted by this, and worried that perhaps our RV plan won't work out after all, so your input would be really appreciated.
Don't feel daunted. Usually you can go to the local Fire Department or Police Department to have them check that the car seat is installed properly.
If the Motorhome does not have the hookups to use the tether straps, the seat belt works just as well. You can skip to about the 2 minute mark in the video Muddydogs posted if you are only using the seat belt. Both methods work fine.
-Michael
Apr-14-2015 01:05 PM
coolmom42 wrote:I don't know where you find all these tether hooks, U bolts, and such, maybe in a class B, but my Class C ( and I believe many others) doesn't have such animals, the forward facing dinette seats, & sofa , has lap belts only & the work just fine, the only shoulder belts are in the front seats, which a child is not allowed to be in anyways.
You will be able to anchor the base of the seat with the seat belt. A 2 yr old will be in a forward-facing high-back seat, with a tether strap & hook at the top of the back, which holds the upper portion of the back tightly to the vehicle seat. You should find a location to firmly anchor the hook, preferably a U-bolt in the floor.
Fasten the seat belt and tether strap,
then put your weight on it with one arm and snug down the straps with the other. The seat should fit VERY tightly to the vehicle seat.
A 2 yr old will be using the 5 point harness in the seat. The shoulder straps should be adjusted in a slot so that they are above the child's shoulders. The chest latch should be at armpit level. You should be able to put the thickness of your hand between the child and the chest buckle. Any more room is too loose. If the bottom fastener between the child's legs has slots for adjusting its position in the seat, it should be moved to the snuggest slot that does not pinch the child.
Any seat that you buy or rent will come with detailed instructions. If you are planning to rent a RV, you should contact the rental agency and ask for details on how the seat can be installed in the vehicle.
It is quite possible the rental agency will have the seat installed and help you adjust it for the child. However you should double-check.
Apr-14-2015 11:08 AM
Apr-14-2015 09:29 AM
Apr-14-2015 09:26 AM
I may not have gone where I intended to go, but I think I have ended up where I needed to be
Douglas AdamsApr-14-2015 08:38 AM
Apr-14-2015 07:27 AM
Apr-14-2015 07:18 AM
