Mar-27-2018 05:40 AM
Mar-28-2018 03:23 PM
Mar-28-2018 08:05 AM
Mar-28-2018 07:22 AM
austinjenna wrote:
I am mostly a weekend camper and just hook up to the city water supply with a filter. If we leave the site and will be gone for a while I turn it off at the supply. I have never been in a situation where the water was turned off at the park. Not saying it doesn't happen but it has not happened to me.
Mar-28-2018 06:36 AM
ricks99 wrote:
It sounds like the main reason that folks advocate using the fresh water tank instead of city water is the eliminate the possibility of a leak or other water intrusion when you're away from the site.
But wouldn't you have to turn off your water pump when you leave, to avoid the same issue?
Seems like the same difference to me -- turning off the city water nozzle or turning off the pump.
Or am I missing something obvious?
Mar-28-2018 06:30 AM
Mar-28-2018 06:26 AM
Mar-28-2018 06:03 AM
Mar-27-2018 09:49 PM
midnightsadie wrote:
changing water source in your diet can ruin a vacation.
Mar-27-2018 07:52 PM
Mar-27-2018 06:54 PM
jplante4 wrote:Mr.Mark wrote:
Jplante4, I agree, a near full tank of water is a not that heavy in the total scheme of things. I would sure hate to run out when I need it most!
MM.
At 100 gallons, mine is 800 lbs. My traveling weight (including 600 lbs of diesel) is just over 22,000 lbs and GVWR is 24,000.
I usually have a one light of fresh water for flushing etc on the road. If I needed to stop somewhere overnight, that would be enough.
Mar-27-2018 04:39 PM
MM.
Mar-27-2018 03:38 PM
Mar-27-2018 03:16 PM
Mar-27-2018 01:11 PM
Mar-27-2018 12:01 PM
