โApr-09-2017 08:04 PM
โApr-11-2017 05:17 PM
Devind33 wrote:FLY 4 FUN wrote:
I just did the exact thing that DSDP Don has described. I found the circuit that I wanted to power up ( 6 plugs plus fridge) and connected just as described. My Xantrex 1800 pro has a built in transfer switch so when dry camping I just switch my fridge to lP and selected plugs are hot (including tv/stereo). If I plug into a pedestal the 110v passes through my inverter and powers all the items on the circuit and of course I put my fridge back to auto. Remote on/off for inverter is also handy. Inverters with this feature cost more but worth it to avoid having to switch breakers etc.
So do you have to turn off the converter or or does the transfer switch take care of the need to do that? Thanks I'm really inexperienced with trailers.
โApr-10-2017 09:26 PM
DSDP Don wrote:
"Devind33"......From the description of your inverter with transfer switch, it should "pass thru" power. This means that when you hook up to shore power, the inverter basically shuts down and uses shore or generator power.
โApr-10-2017 08:36 PM
โApr-10-2017 08:17 PM
โApr-10-2017 07:33 PM
โApr-10-2017 06:49 PM
โApr-10-2017 02:27 PM
โApr-10-2017 12:33 PM
โApr-10-2017 10:38 AM
Devind33 wrote:I intercepted the shore feed to the main box with my hard-wire inverter/xfer switch. Works well. SPST kill switch on converter. HW breaker off.
Also is there a better way to run the outlets? Mostly looking for the two TV's one in main cabin one in the bedroom
โApr-10-2017 01:06 AM
โApr-09-2017 11:00 PM
lawrosa wrote:ScottG wrote:
I added a HD, 20A light switch for the converter. I used its wire that went to the breaker and rerouted it to the switch. Then I added another wire back to the breaker.
Doesnt that charge wire charge more then 20 amps depending on convertor?
But I guess for whatever reason its on a 20 amp breaker...
Wouldnt a battery disconnect suffice?
โApr-09-2017 10:27 PM
โApr-09-2017 08:46 PM
โApr-09-2017 08:30 PM
