Cummins onan oil change
thehippie
I have brand new toy hauler with new Cummins onan 4000. Is the first oil change at 25 hours then every 100 hrs thereafter?
6 REPLIES 6
fyrflie
Rather than tell you what I do, here is the answer to your question.
From the Cummins RV generator handbook.
“You should change the engine crankcase oil after the first 20 hours of operation, and every 100 to 150 hours thereafter. “
https://power.cummins.com/sites/default/files/literature/rv/F-1123-EN.pdf
ksg5000
That sounds about right - first oil change is usually 20-50 hours depending on model and then about 100 hours or at least annually.
Kevin
IB853347201
I believe the owners manual will advise as to the correct Oil Change interval. Ours is a 5500 and the interval is at least 150 hours. Make sure you follow the recommended interval and use the recommended oil grade. Don't forget to change the filter each time as well. Our oil grade is 15W40 as recommended for the North American climate.
2010 Suncruiser
souraider
I never hit 100 hours per year so I change yearly...usually early spring time when I am also taking it out of its winter hibernation. There is no oil filter, just a simple drain-and-replace.
'17 F350 STX 6.7
'15 Stealth WA2313
'20 Can Am Maverick Sport 1000R
Bobbo
When I had my ONAN, I just changed the oil every spring when I de-winterized. Of course, we probably never hit 100 hours of use per year.
Bobbo and Lin
Sam_Spade
If this really is a "brand new" RV, there should be an owners manual for the generator in there somewhere. If not, see your dealer.
I think both my Onan's have had a 150 hour service interval.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
