Drawers in a Travel Trailer
Alabama_Jim
I asked for ideas on how to keep drawers secure while traveling. Got several ideas. I bought the male/female latch like on cabinet doors. Now I have a problem. When going to mount the female end, I have about 5 inches of space and cannot get a screw driver long ways to put the screw in. Any ides? Will glue hold it in place?
11 REPLIES 11
PUCampin
My drawer slides did not have a latch mechanism, the drawers and cupboard doors each had one of those tabs that fits into spring rollers. Works ok for most doors and drawers, not so much the big pot drawer under the stove. I lost count how many times that thing came open and had the slide come apart. I finally replaced the slides with heavy duty soft close from Home depot. That helps keep it closed, I also added 2 more of the tab/roller catches. Better now.
2007 Expedition EL 4x4 Tow pkg
1981 Palomino Pony, the PopUp = PUCampin! (Sold)
2006 Pioneer 180CK = (No more PUcampin!):B
Me:B DW:) and the 3 in 3 :E
DD:B 2006, DS ๐Ÿ˜› 2007, DD :C 2008
Opie431
Years ago my husband listened to my complaints and was going to finally fix the drawer that opened when traveling. He found all he had to do was tighten what was already there. Before you do anything else, see if that is the problem.
Vulcan_Rider
enblethen wrote:
In many rigs, you must lift the draw when it is closed to allow it to open.
And in some, there is a magnet.
And in others, there is a spring loaded "clamp".
Are you sure you are getting the drawers closed all the way ??
The last one I saw without anything was a tiny little TT built in 1965.
BTPO1
ScottG wrote:
They make very short screwdrivers or even right-angle attachments for power drills.
Glue wont hold.
X2, they also have ratcheting right angle screwdrivers that accept different tips. JMO
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
enblethen
That is a separate stop.
There should be one that is activated when the draws are closed.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Alabama_Jim
enblethen, the drawers do not come all the way out, as to the floor. They just come half way out.
enblethen
Look at the end of the drawer guides mounted in the cabinet. There should be small dog ears that need to be bent out so you have to raise the draw slightly to pull them out.
Bud
USAF Retired
Pace Arrow
NanciL
I have a screw driver that has the ends bent at a ninty degree angle just for stuff like that.
One end is Philips and the other is a slotted.
They are inexpensive
Jack L
Jack & Nanci
K_Charles
I don know what kind or drawers you have but I thought they all had a latch that was right in the track. We never had a drawer open in all the campers we have had.
Maybe you just need to fit the track.
Vulcan_Rider
What kind of an RV do you have with drawers that do not already have some kind of friction latching mechanism ??
ScottG
Glue wont hold.
