โDec-05-2013 10:23 AM
โDec-09-2013 09:15 PM
โDec-06-2013 10:11 PM
Porsche or Country Coach!
โDec-06-2013 02:41 PM
โDec-06-2013 02:19 PM
Jonnygsx wrote:pianotuna wrote:
Hi Jonny,
In regards to the Herculiner at least one rv'er has used it for roof repair.
As to the batteries, placing them in a steel box would protect them. As to bounce that's news to me--and I do not believe it would a problem with modern batteries.
HA I would have never thought to use Herculiner. Is there any benefit to use that on a rubber roof. Cost wise it doesn't seem any cheaper than a liquid EPDM coating.
Hrm well now I am torn on the battery install location. My stock bumper is just 4" x 4" steel I believe. Is that strong enough to bolt a battery box to or would it need to be reinforced?
โDec-06-2013 12:14 PM
pianotuna wrote:
Hi Jonny,
โDec-06-2013 12:07 PM
โDec-06-2013 10:07 AM
โDec-06-2013 09:59 AM
Hi,
Coat the roof with Herculiner.
Then install the new battery bank at the rear bumper on a rack welded to the frame. Run #6 wire to the OEM connection or to the power center which ever is easier.
I assume you are messing with me now. Herculiner the black truck bed coating does not seem like a good plan.
Wow really? I read a few threads about how it was a very bad idea to install batteries on the rear bumper. I had had that thought too, but most of the threads said that is one of the bounciest spots on the trailer and would damage the batts over time. Also if you were to back into anything or to be rear ended in a wreck battery acid could be all over.
โDec-06-2013 08:55 AM
โDec-06-2013 08:53 AM
pianotuna wrote:
Hi,
โDec-05-2013 01:22 PM
โDec-05-2013 01:21 PM
โDec-05-2013 10:34 AM
