First time full hookup site
ams1130
We are not beginners at RVing, but this summer we will be staying for the first time at a park with full hookups (a five day stay only). For our waste tank dumping we've previously just used the blue slinky hose and used the dump station's lid (or whatever it's called) to hold the hose in place.
Should I be purchasing a 'better' hose, and do I need an adapter to hold the slinky in the hole? We know to not dump until the tank is mostly full.
Ford F150
2014 KZ Sportsmen S242SBH
16 REPLIES 16
ams1130
Thanks again for the advice.
Ford F150
stevemorris
we dont do or use anything special
pull the regular slinky hose out, dump, rinse and put the hose back
always early in the morning when nobody else is around, preferably somewhat breezy.
2017 Ram 1500 4door, 4x4, 5.7 l hemi, 8 speed
2008 KZ Spree 260
ncrowley
To hold the end of the hose in place, I use a "sewer pig". You fill it with water for weight and it fits snugly over the end of the hose. Plus it is fun to look at.
Nancy
Newmar Northern Star
wanderingbob
For a five day stay you may only dump once , stick the hose in , dump , put the hose away . Do not buy nuttin till you need it !!!
skipro
+1 on the Rhino Flex hose.
Lynnmor
For those sewer pipes with no threads, I sometimes use the long nail type of tent stakes with some twine.
Dutch_12078
Tom/Barb wrote:
Alabama Jim wrote:
Your current hose is okay, you do need to get a L shaped adapter to screw on the end for placing into the dump at your campsite.
I've never seen one of those that didn't leak.
Our Camco Revolution hoses and 'L' adapter don't leak. Been using them since 2013.
For the OP: For those situation where the dump port isn't threaded, I carry a sandbag that's sold for adding trunk weight in the winter. It drapes over the hose end and holds it in place.
Dutch
2001 GBM Landau 34' Class A
mowermech
We just spent a couple nights at the Famcamp at Malmatrom AFB.
Our elbow adapter did not leak.
However, I did learn to not tighten the hose connectors fully when putting the hose away. After several months of being put together tightly, they stick, and are VERY difficult to take apart!
CM1, USN (RET)
2017 Jayco TT
Tom_Barb
Alabama_Jim
lanerd
Yes, and yes. However, as mentioned, a "better" hose (like the Rhino mentioned above) doesn't need any additional adapters. Rhino is even available at Walmart and you can get "extensions" of different lengths to fit without any modifications.
An additional plus to using a stinky slinky like this is that it is a "closed system"... meaning if all connections are tight, no odors or leakage will occur. Makes for happy neighbors.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
ams1130
Thanks, everyone.
Ford F150
BB_TX
We use a Rhino sewer hose. The end has a stepped three different size threaded end. Many parks have threaded sewer connections. But many also simply have a plain PVC pipe. Most of the time the Rhino will simply push into the PVC pipe and one of the three steps will provide a tight enough seal. But I also carry a sewer donut for those cases where it will not.
Tom_Barb
We use this type of sewer hose. It will screw into the camp ground's pipe. and be secure.
no heavy rock required.
