From SFO to Cloverdale is a nice short run. There are 3 campgrounds near there,
Dutcher Creek. It is small and is a good overnight stop,there is
Fritz Winery near by you will see the signs to it if you get off at Dutcher Creek exit then turn left you will see the sign. Don't be afraid of the small road in,I took my RV in and there is a large parking area.
There is the also
the KOA it is farther off the road and not easy to get to.
I would suggest looking at Yelp on these and make up your mind. Also
Camp Ground ReviewsAs for the next day the Redwood are not far away,an easy 2 1/2 hr driveup 101.
I would suggest
Burlington Campground on the Avenue of the Giants,next to the visitor center,
As seen here space 17
In the middle of the week you will have the place to yourself.It is a nice 2 day stay
If you exit at Myers Flat on the way to Burlington there is a Winery on the left.
There is also Ancient Redwoods RV park but it is a treeless parking lot but you can walk to the forest.
Hope this helps.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTECFormer El Monte RV RentalRetired Teamster Local 692Buying A Rental Class C
