Gas Grills?
bazaarsoft
Looking for suggestions on grills: what does everyone do? We're thinking of getting a propane grill that we can hook to the outside gas connection. If that's what everyone does, which grills are best? Any that have problems?
2011 Nissan Armada, 5.6L V8
2012 Dutchman 296FKS
42 REPLIES 42
therink
Tachdriver wrote:
sch911 wrote:
Weber Q100, 120, 200
And the gas adapter.
Exactly what I have except I removed the regulator on the Weber Q and installed the female threaded mail quick disconnect I retrieved from my old side kick grill. Seems either way they both work.
X2
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
Ron3rd
Weber 200 is hard to beat. I also recommend the Weber rolling cart accessory. It fits both the Baby and Full Size Weber Q.
If you go with a Weber, here's how I converted mine:
Weber Conversion For Regulator Removal.
Equilizer Hitch
Honda EU2000
fla-gypsy
Weber Q 220. The Weber Q series is the best built small grill I have ever seen.
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
WyoTraveler
Camco makes a conversion kit. The quick disconnect works with any grill. Thatcway you don't have to carry propane inside your vehicle or RV in unventilated areas. Check out amazon & camco number 57638. You do need the additional fitting plumbed into your RV.
travelzoo
The best gas grill I have found for the money is this ONE You can find them for around $85, the legs are attached and fold to take up a small area for storage. It's very wind resistance and you can put a tap off any propane tank on it. There is also a table top model.
rtaylor0830
I have the weber q and the adapter but i can not get the adapter to let the propane in any suggestions
Beverley_Ken
Another happy Webber Q RVer, also prefer it at home.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
downtheroad
GREAT SUGGESTION - looks exactly like ours. Just add....
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
1oldtruck
RVQ Grille. Have it plumbed into the gas line.
bazaarsoft
Thanks for the speedy replies. I did stumble across this thread which makes it sound a bit complicated. Maybe the adaptor you specify alleviates all that other stuff?
Tachdriver
Awesome grills BTW
Tachdriver
sch911
OEM Auto Engineer- Embedded Software Team
