โMay-11-2015 06:05 PM
โMay-21-2015 02:51 PM
stevec22 wrote:pxt wrote:marquette wrote:
Where did you get your tow capacity rating? 5200 lb with the Z82 towing package seems like a pretty light rating. Is there a rating listed with a WDH and a listing without a WDH? I know my Suburban rating change with or without a WDH.
I called chevy manufacturer
What size engine?
What does the yellow door sticker show for trailer capacity?
As stated above, that seems low for a Tahoe. My 2005 Yukon says 6900 as max tow.
โMay-20-2015 06:17 PM
โMay-20-2015 05:26 PM
โMay-20-2015 07:35 AM
โMay-20-2015 02:08 AM
pxt wrote:
If I pack the trailer light? Would that keep me under and help? My trips would be short mostly local.
โMay-19-2015 06:27 PM
โMay-12-2015 05:48 PM
mowermech wrote:Very true. I tend to use GVWR as a weight that should never be exceeded as compaired to dry weight which nobody will ever see in actual use. If people need to look at just ONE number then GVWR would be that number. Everyone should go to a scale and find the ACTUAL loaded weight.
Actually, the GVWR of the trailer is nowhere near as important, IMO, as the ACTUAL weight of the trailer as loaded and ready for use....
Reese Dual Cam Straight Line HP Sway Control
โMay-12-2015 02:50 PM
โMay-12-2015 02:28 PM
โMay-12-2015 11:22 AM
โMay-12-2015 10:54 AM
โMay-12-2015 09:39 AM
pxt wrote:Chances are "YES", if you change the axle ratio to 4.10 chances are the max. trailer towing rating will change to 6200 lbs. Check the Owner's Manual. Is that what you mean by more beefy?
Is there anything I could do to my tv to make it more beefy?
โMay-12-2015 09:35 AM
โMay-12-2015 08:15 AM
