โDec-30-2016 07:59 PM
โJan-01-2017 08:37 PM
โDec-31-2016 11:41 AM
โDec-31-2016 10:48 AM
rskrbina wrote:afidel wrote:time2roll wrote:
If that modern converter is a WFCO all bets are off. Measure the voltage after a week and see if you actually see storage mode at 13.2 volts.
Regardless you still need to check the water level periodically.
See, that was my worry. It's a two hour round trip (during good weather) to my storage so the chances of me going during the next few months are pretty much nill. I think I'll pick up a timer and just set it to go for an hour or two a day which should be plenty to keep up with the small parasitic loss from the CO/LP detector and the stereo (or should I pull the stereo fuse?).
Hello Andy. Use your battery disconnect switch and you won't have to worry about parasitic loads while storing your rv.
โDec-31-2016 10:43 AM
theoldwizard1 wrote:
If you are concerned about overcharging, buy a cheap mechanical lamp timer and install it between the power source and the charger. Set it to run for a couple hours per day.
Next time you are shopping for a house battery make sure to get a TRUE deep discharge battery. Most "marine" batteries are dual purpose and therefore are a compromise between starting and powering things.
โDec-31-2016 09:59 AM
sonora wrote:
Would a mid 90's converter be an "older" one?
โDec-31-2016 09:28 AM
โDec-31-2016 07:37 AM
โDec-31-2016 06:53 AM
sonora wrote:Ava wrote:
It is the older converters that do not have a three stage charging cycle that are hard on batteries. The continuous charge on older units can boil the battery dry if not checked on regularly as far as I understand.
โDec-31-2016 06:25 AM
โDec-31-2016 06:24 AM
โDec-31-2016 06:02 AM
โDec-31-2016 05:09 AM
โDec-31-2016 04:36 AM
afidel wrote:
I have indoor climate controlled storage with power available. My question is how bad will a modern 3 stage converter really be to a marine battery over that period of time. Do I really need to go out and buy a charger that costs half as much as a new battery ...
