Installing P3 break controllers to 2015 F150
er78mph
Hello to all and my apologies for re-post
Attached is a picture of what I have to work with. My question is, do I just link the wires to one another and then place the plugs into their perspective houses? Grey under the dashboard and black to P3?seems fairly easy but just want to be 100% sure. Thanks, again!
7 REPLIES 7
mbopp
I spliced my P1 harness into the Ford harness. If you go that route, splice by function and not by color. I also mounted the P1 in the stock location. Over on the F150 forum there were pics posted on taking the dash apart to do this, there's probably YouTube videos by now.
2019 F250 XLT Supercab
Just DW & me......
Lynnmor
I would skip the P3 and get a real Ford controller on Ebay. Way better.
er78mph
Ill just get the harness, thanks!
Chuck_thehammer
order or purchase the adaptor for your truck.. plug and play to P3
I removed my P3 from my Dodge this summer but the Ford had the Ford brake controller from the factory...
Dodge, I did the adaptor .. all so EASY.
UNLESS, your truck does not have the Towing package..
then 4 wires from controller into wires under the dash
and 7 wires to rear bumper..
Dandy_Dan
Er78, You should be able to get a harness that will plug into the trucks wiring under the dash then just match wires per instructions and plug it in.
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
2oldman
downtheroad
Use this to post your picture
>>>HERE<<<
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
