Jun-04-2021 06:25 AM
Sep-01-2021 06:09 AM
Aug-25-2021 03:49 PM
Horsedoc wrote:Combo microwave/convection ovens are certainly more expensive than microwave (only) ovens. But I do think that part of the cost difference is that they are marketed "for" RVs.
My kitchen microwave does not have convection like the one in the MH.
Is/could that be the difference in prices?
Aug-25-2021 04:50 AM
Aug-24-2021 03:17 PM
wa8yxm wrote:Actually, the range hood/light on my microwave was indeed 120VAC, even though it was the original microwave that came in the motorhome. :S4x4van wrote:
There is more than just the microwave's size and venting to look at. Many (most?) RV microwaves incorporate a stove hood/vent & light as well into the bottom, for the gas range below. If yours does, then any replacement should be built-in model designed to go above the stove and include those features.
Some do, So do some residential models.. same same I just went residential microwave shopping so I got to see some. One difference (Well two) is that the range hood is 120 vac on the residential models and 12VDC on the RV types.. But the microwave is the same. (Change the fan motor and the light bulb to convert).
Aug-24-2021 01:47 PM
Aug-24-2021 11:38 AM
AlmostBoatless wrote:The display was bad on the Sharp microwave in our '04 Itasca when we purchased it. I was able to find the display board part number on an online appliance repair site, and then found the unit on eBay for less than $25. Took about 20 minutes to install, without ever having to remove the microwave from it's mounting.
We need to replace or fix our Dometic CDMW12B microwave. The number pad does not work. Have you found any unit that will fit the braces top and bottom? If anyone has done this, please help!
Aug-23-2021 04:35 PM
shum02 wrote:
then you get greystone, which is not the same as any other brand for issues like the motherboard.
Aug-23-2021 09:23 AM
Jul-28-2021 01:56 PM
Jun-06-2021 05:47 AM
StirCrazy wrote:wa8yxm wrote:
What is the difference between an RV microwave like the Dometic CDMW12B and a Home Microwave like the LG CDMW12B (note they are the same model number)
The door on the Dometic says DOMETIC and the one on the LG says LG.
Now because of the way the dometic was originally mounted the installer did some sheet metal work to duct exhaust air but the microwave itself is identical to the Lucky Goldstar. and in case you are wondering I've never been lucky enough to have Goldstar products work (So the one that is now in my apartment kitchen is a CDMW12B/yxm the suffix means I re-designed part of it, did some machining and replaced one LG part with a GE part, now it works great).
But the reason for the ducting is originally the unit was installed in a closed cabinet the mounting flange had vents and they routed exhaust air into the flange... AMANA's vent to the front (At least the 2 I had did). so that would not be needed
if the compartment is open.. you don't need to do that (I eventually opened the compartment)
but the mirowave... Is identical save for the name Dometic on the door . Oh and the price tag.
then you get greystone, which is not the same as any other brand for issues like the motherboard. mine recently went, but it was just a lose wire in a cheep plug. if it would have been the motherboard it would have been junk because the repair shop couldnt trase the numbers on it to anywhere. some times I envy your prices in the US, 40 bucks for microwave that would cost 150.00 here and the rv ones are about 450.00
Steve
Jun-06-2021 05:25 AM
Steve
I bought a microwave at Cdn Tire a while back for $75. If I wait for a sale bet I could push $65. With exchange that is about the same. MasterChef house brand.
Jun-05-2021 06:43 AM
Steve
Jun-05-2021 05:21 AM
Jun-04-2021 06:22 PM
