replacing electric brakes
Casinojunkie
I have a 5th wheel 12 years old and am planning to replace the brakes and pack the wheel bearings and replace the hub seals.
It has 2 6,000# axles and hubs are 12" 6 hole.
My questions are 1. without taking it apart would the brakes be 12" x 2"? 2. Is the original electric actuator ok to use? 3. Is it best to replace the brake shoes, springs etc, or purchase the brakes installed on the 5 hole backing plate? 4. Where can the parts be purchased? 5. Is packing the bearings with Super Tech grease the correct grease to use, and should the void in the hub be filled with grease? 6. Where can the correct grease seals be purchased? I used to pack my own automobile wheels and install the brakes.
Any help would be appreciated. Thank you.
1997 Dodge Ram 3500 Diesel, automatic, pyro-boost-tranny temp on pillar mount, 354 rear gears, prodigy brake control,
2002 26' Lakota 5th wheel, 3-slide, by McKenzie
8 REPLIES 8
Dandy_Dan
For Dexter Axles, bearings and grease seals can be had from an autoparts store. At least ours were and were American parts.Bearings i believe were Timken.
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
jamway
Look at this place.
http://www.easternmarine.com/Electric-Trailer-Brake-Assemblies/
Look here too. They had free shipping a few days ago. They may still have it.
http://www.etrailer.com/dept-pg-Trailer_Brakes.aspx
Happy Camping
2004 2500 CTD HO LB 4X4 auto
2005 Discover America 29 RL
James
352
Buy the backing plate package and a drum to match it. Do it right the first time. Magnets and drums !!!!!!!!. Do the research.
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
ScottG
I'd do the whole assy. The electric magnet is probably worn down too if the pads are that bad.
OH48Lt
There are some complete brake kits on ebay, competitive priced, brand name (Dexter Al-co, etc).
2017 Ford F-150 Crew Cab 4x4 3.5 EcoBoost
2014 Cruiser RV Fun Finder 215WKS
2015 Harley Road Glide Special in Amber Whiskey
2019 Mustang Bullitt
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
TucsonJim
I purchased the complete 12x2 brake package from my local camping world. They were about $79 and included five new mounting nuts/washers and electrical connections. Even though my trailer had manual adjusting brakes from the factory, I purchased self adjusting brakes so I don't have to crawl under the trailer every 3000 miles to adjust the brakes.
I ordered the grease seals from E-trailer.com.
You'll need to pull one of the wheels to verify the grease seal number you have and to confirm the brake size.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
I second the whole assembly.... cut the wires , usually 4 bolts off and 4 back on.. re-connect wires.. brake job complete ! It really does not get any easier!!! Just remember that there is a right side and left side kit for some ( or all??) as far as the size.. YOU will have to verify that part ..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
donn0128
You need to jack it up and look. I could be either 12X2 or 12X2-1/2. When you figure it out, just go buy the whole assemblies. They are usually about 50 dollars each.
