Jul-03-2014 06:31 AM
Jul-15-2014 12:29 PM
opnspaces wrote:Clay L wrote:
The flapper in the air admittance valve on the output side of the trap under the sink can stick in the open position and let gray tank odor into the bathroom.
They usually unscrew pretty easily by hand and replacements can be found in hardware stores.
Here's a link to an air admittance valve from Home Depot. They are cheap enough that if you have a sink in the bathroom you might just want to just change it LinkBurwoods wrote:
Thank you ... we have a problem with the toilet not holding water. DH happens to sell the one that is in there now, so we will replace it at the same time we remove the carpet from the bathroom.
I think the toilet not holding water is your most likely culprit though. Get the toilet fixed and the smell will probably stay away.
Jul-15-2014 12:23 PM
Jul-14-2014 02:55 PM
Jul-14-2014 01:47 PM
Ron3rd wrote:Clay L wrote:
The flapper in the air admittance on the output side of the trap under the sink can stick in the open position and let gray tank odor into the bathroom.
X2, and had to replace an Air Admittance Valve on my old trailer (also called a "cheater vent") Picked one up at Lowes. Our smell was coming from under the kitchen sink BTW. A gray tank can stink as much as a black tank. They do make cheap ones and better ones with higher quality valves. They are a standard size and simply screw in. I think mine was around $8 at Lowes.
Jul-14-2014 01:03 PM
navegator wrote:
Shower and sink "P" traps some times retain residual soap that rots out even if you constantlly dump water, I use a small thin hose that I attach to the shower hose and spay and snake the traps clean, water on the toilet shoul hold and not drain, if it does the seal is compromissed.
navegator
Jul-14-2014 12:42 PM
Jul-14-2014 10:31 AM
Jul-03-2014 02:52 PM
Jul-03-2014 11:44 AM
Jul-03-2014 11:17 AM
Jul-03-2014 09:31 AM
Bobbo wrote:
Febreze
Jul-03-2014 08:52 AM
Jul-03-2014 07:59 AM
Jul-03-2014 07:49 AM
