Oct-07-2014 06:28 PM
Oct-08-2014 06:28 PM
NekkidFish wrote:
Thanks everybody! This one does have an upgraded Serta mattress. I will look at the gripper things, as well as sewing the top sheet to the fitted sheet! That is an excellent idea!
Oct-08-2014 07:06 AM
Oct-08-2014 05:02 AM
FrankShore wrote:mobilefleet wrote:
the standard size for RV queen beds is 60x74
Not true. Many manufacturers are using residential queen beds in their RV's!
Oct-08-2014 01:06 AM
Oct-07-2014 07:20 PM
Oct-07-2014 07:10 PM
Nutinelse2do wrote:NekkidFish wrote:
In the flyer for our RV it says that the queen bed is 60x80. But, when I look at all of the Queen sheets on Camping World, they are 60x75.
Is that so that the fitted sheet is real tight?
I know I don't want to get sheets out in the store, as the fitted sheets are made for deep mattresses nowadays, and it will be all loose. 😞
Thanks! Jules
Hi Jules.
To answer your question, the " rv queen " is 60x74. Also known as a " short " queen. There are still coaches being sold with that size. Most manufacturers over the past several years have changed to the " standard queen " which is 60 x 80.
Regarding the sheets, just use the " standard " queen sheet size. No need to purchase special sized sheets. Regular sheets work well though you might have to tuck one edge a little bit. Also, using a topper on the mattress will fill up the sheet a little bit.
You might find you need a topper since most rv mattresses from the factory are garbage, and uncomfortable. For this reason, most choose to replace the " rv mattress " with a more comfy " standard " or home mattress.
Cheryl
Oct-07-2014 06:59 PM
Thanks! Jules
Oct-07-2014 06:54 PM
Oct-07-2014 06:47 PM
Oct-07-2014 06:40 PM
Oct-07-2014 06:38 PM
Oct-07-2014 06:29 PM
