โApr-23-2018 06:21 AM
โApr-23-2018 05:30 PM
โApr-23-2018 01:20 PM
โApr-23-2018 11:10 AM
Old-Biscuit wrote:
YES while on shore power the converter will charge the trailer battery while using the 12V DC Heater on fridge.
BUT other then checking the amp draw/DC Element getting HOT it will NOT cool a fridge down.......it is only capable of 'maintaining' an already cold fridge
OK to 'test' the DC heater system----just don't get flustered cause fridge doesn't get cold.
โApr-23-2018 08:30 AM
โApr-23-2018 07:32 AM
โApr-23-2018 07:07 AM
rightlaneonly wrote:Go right ahead.
I want to test it while its parked to be sure it operates on the 12 volt side.
โApr-23-2018 06:58 AM
naturist wrote:
Assuming yours is one of the ones that actually operates on 12v as well as propane/120 volt, the answer is yes to both questions. Do be aware that it will obviously be best run on propane when boon docking, but in your driveway, with shore power, should be no problem.
For what it is worth, the 12v option is best used for "while traveling" to keep things cool without turning on the propane. Do also be aware that absorption refrigerators cool down slowly, with 12v probably being the slowest option. I'd turn it on, and ignore it for 24 hours before bothering to check it. Into the bargain, when you load it up to go on a camping trip, best to give it that day's cool down, and then pre-cool everything in the household refer so the camper doesn't have to do ALL the work. When they are working as designed, the do a great job keeping things cold, but cooling down, not so much.
โApr-23-2018 06:55 AM
Isaac-1 wrote:
Most RV refrigerators operate on propane or 120V AC shore power, the 12 volt part only powers the control system.
โApr-23-2018 06:54 AM
โApr-23-2018 06:23 AM
