โSep-06-2016 07:29 AM
โSep-07-2016 04:13 PM
โSep-06-2016 11:45 AM
โSep-06-2016 11:36 AM
โSep-06-2016 10:06 AM
โSep-06-2016 09:44 AM
mabynack wrote:yeah I already pulled the drum and didn't see anything but I haven't check the voltage to each wheel.
I would pull the drum to see what's going on. I've seen that happen when a spring breaks or when the shoe has been contaminated.
The next step would be to check the voltages going to each side to make sure they're correct. Loose or dirty connections can reduce the current flow to one wheel.
โSep-06-2016 09:13 AM
โSep-06-2016 08:35 AM
K Charles wrote:it just started doing it 20 or miles ago
Has it been that way the whole 800 miles?
โSep-06-2016 08:34 AM
corvettekent wrote:fully loaded
Is this a flatbed (car) trailer with no weight on it? Mine will lock up too if it is empty but works fine with a load on it.
โSep-06-2016 08:28 AM
โSep-06-2016 08:27 AM
โSep-06-2016 08:01 AM
